A flexible, weather-resistant outdoor security camera that puts pro-grade security exactly where you need it. Stick it up anywhere you want to see and hear more with advanced features like 3D Motion Detection, HDR video, and Audio+.
The wire-free design of Stick Up Cam Pro Battery lets you place it on a flat surface for flexibility, or put it on the wall or ceiling with the included camera mount for a more permanent solution.
- Ring Stick Up Cam Pro Battery - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount, ceiling mount
- 7 cm x 7 cm x 15.39 cm
- Black
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa
- Cables Included
- 1 - USB power cable
- Smartphone Monitoring, High Dynamic Range (HDR), Motion Zone Alert, Colour Night Vision, remote siren operation, 3D Motion Detection, Bird's Eye View, customisable motion zones, built-in siren (85 dB)
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 48.5 °C
- Audio Support
- Camera Mount Type
- Wireless
- 7 cm
- 7 cm
- 15.39 cm
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Video Capture Resolution
- 1920 x 1080
Lens Construction
- Horizontal Field of View (degree)
- 139
- Vertical Field of View (degree)
- 80
- Diagonal Field of View (degree)
- 155
- Network Interface
- Ports
- USB (power only)
- Included Accessories
- Mounting kit, security sticker, USB cable, battery
- Cables Included
- 1 x USB power cable
- Black
- Power Device
- Battery
- Software Included
- Ring Protect (30 days trial)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Limited warranty - 1 year
- -20 °C
- 48.5 °C
