Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
TP LINK Tapo T300 V1 - Water leak sensor
Quicklinx: HLVRWS00 Mfr#: TAPO T300
Type: Water leak sensor
Compatible With: [N/A]
More than 50 In Stock
£16.66 ex VAT
£19.99 inc VAT
The Tapo Smart Water Leak Sensor notifies you via different methods in case of an emergency. Receive instant alerts immediately when a water leak occurs, so you can respond quickly to prevent further damage.
  • Drip and leak alert
    Features 6 highly sensitive sensor probes to quickly and consistently respond to drips and leaks for faster protection of your property.
  • Built-in 90 dB alarm
    Alerts you immediately with its adjustable 90 dB alarm when leakage occurs. Press once to silence the alarm after you find the spot.
  • Instant App notifications
    Receive an instant app notification when a leak happens. Find out even while away from home to prevent worse water damage.
  • Tapo hub alarm
    Tiggers the Hub alarm for additional audible alert coverage in your home when water leakage is detected.
  • Visible alarm with smart lights
    Set up Smart Actions in the Tapo app to get a visual alert from your Tapo smart lights before disaster strikes.
  • IP67 rating
    Provides high-grade water resistance and dust protection and a long service life. Ideal for humid and dusty environments.
  • Flexible placement
    No wiring required and simple to use. Place the sensor anywhere leaks or flooding may occur, like near a washing machine, water heater, sink/bathtub, and more.
Tapo T300 V1 - water leak sensor - smart
Water leak sensor
Sensor Type
Water leak
Functions
Water leak detection
Power Source
Internet of Things (IoT) Platform
Tapo
Wireless
Frequency Band
868 - 922 MHz
Remote Management Interface
Wi-Fi
8.45 cm x 4.65 cm x 3 cm
Water leak sensor
Sensor Type
Water leak
Functions
Power Source
Wireless
Wi-Fi
Frequency Band
868 - 922 MHz
Waterproof, real-time notifications, alarm mode, LED indicator, drip and leak alert
Hub Compatibility
Tapo Hub
Compatible Application
Tapo app
Platform
Tapo
Communications Technology
Wi-Fi
AAA / LR03
Required Qty
2
Voltage Provided
1.5 V
Battery Lifetime
1 year
2 AAA batteries
IP67, IP66, FCC, R-NZ, JRF, NCC, RCM, RoHS, UKCA, VCCI
8.45 cm
4.65 cm
3 cm
0 - 99% RH
Brand: TP LINK
