Fujitsu ScanSnap iX500 Document Scanner Duplex 216x863mm 600dpi 25pp
Quicklinx: CH2VWS00 Mfr#: PA03656-B301
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Scan documents and access them anywhere, anytime with the Fujitsu ScanSnap iX500. With an intuitive wizard that guides you through every step of the scanning process, you can digitize your important documents and files for storage and viewing across a range of popular cloud services or send them wirelessly straight to your iPad/iPhone and Android devices. Scan your everyday documents with simple, automated settings; from business cards to A4 and even A3 paper and then send the data to Word, Excel, PowerPoint, to an E-mail address, and SharePoint for sharing with work colleagues, friends, and more.
The iX500 comes with a built-in, dual-core "GI" image processing engine that takes ScanSnap to the next performance level. This powerful new CPU enables scanning via Wi-Fi to your tablet or mobile device (iOS and Android), with enhanced scanning speeds regardless of your connection or target device. You can wirelessly operate the scanner using your smart device and the ScanSnap Connect App to create high quality scanned images that can be saved to the device, edited, and distributed via email, SharePoint, and more.
The iX500 offers the paper feeding performance of expensive high-speed, high-volume devices, enhanced through USB 3.0 support, at an affordable price that won't break your office budget.
Create PDFs of your documents easily with one-touch activated automatic settings and automatic image correction functions. Just place a document in the scanner's paper chute, press the "scan" button, and the iX500 starts scanning right away, with the ability to simultaneously scan up to 50 two-sided pages at a speedy 25 pages per minute.
The iX500 is designed to take the hassle out of pre and post scan involvement thereby freeing up time for other tasks. The iX500 will automatically detect the size of the document scanned and display a cropped image accordingly, scanned images will be automatically rotated, any scan skew eliminated, blank pages deleted and color is detected to help minimize file size.
With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
A few simple steps to digitize and manage the information on your receipts. ScanSnap Receipt allows you to easily scan and extract information from your receipts, and export the data for other accounting software. The sophisticated features within ScanSnap Receipt automatically support various languages and currencies.
The bundled business card scanning software scans large volumes of business cards into digital business card holders, and enables you to transfer business card information into Excel, Outlook Express, Salesforce, and other databases for future reference.
The Quick Menu can be set up to display your 'Favorite' scanning destinations or will 'Recommend' an application. Scan a business card, for example, and the Fujitsu iX500 will automatically recognize the size and recommend a list of installed business card-related applications.
Create editable Microsoft Word, Excel and PowerPoint files using the included ABBYY FineReader OCR software.
Seamlessly scan to services such as Evernote, Dropbox, Google Drive, Salesforce, or Sugarsync. View and share your documents anywhere and anytime. Now with ScanSnap Cloud your scanned documents will be automatically recognized and routed straight to your preferred cloud account.
Includes Nuance Power PDF for Win and Nuance PDF Converter for Mac - The bundled Nuance software allows users to read directly from cloud based applications and to save directly to those cloud based applications meaning that the possibility of using and sharing digital documents is extended.
  • Easily transform paper with the touch of a button
    Achieving organization with the ScanSnap iX500 starts with the touch of a single button and ends with a host of productivity features that keep you ahead of the stack.
  • Wi-Fi or USB connectivity to a computer
    Break free from USB and place ScanSnap just about anywhere in the room with Wi-Fi connectivity to a PC or Mac.
  • Scan directly to mobile devices
    Quickly bypass the computer altogether and scan a PDF or JPEG file directly to an iOS or Android mobile device or tablet.
  • Fast double-sided scanning
    Typically, higher quality means lower performance, but the iX500 maintains a speed of up to 25 pages per minute even at 300 dpi in color!
  • Built-in "GI" microprocessor
    A dual-core CPU-mounted "GI" processor performs the intelligent image enhancement responsible for great looking images with dramatically faster results and more sophisticated connectivity.
  • Advanced paper feeding system
    Inheriting the superior paper feeding technology of the professional-grade scanners, iX500 achieves exceptional feeding reliability using "Separation Roller" technology to minimize jams and multi-feeds.
  • Advanced paper detection
    ScanSnap iX500 is equipped with an ultrasonic sensor that can be turned on to help operators avoid losing images. What's more, an interactive interface allows users to easily bypass intentional double-feed such as a taped-receipt on an expense report.
  • Accelerated searchable PDF creation
    Making PDF files searchable at the point of scanning is a great way to keep them instantly accessible and now you can create a searchable PDF at nearly the same speed as a standard PDF.
  • Compatible with PC or Mac
    The ScanSnap iX500 works on both Mac and PC operating systems, making flexibility a breeze.
  • ScanSnap Receipt
    The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
  • ScanSnap Sync
Fujitsu ScanSnap iX500 - document scanner - desktop - USB 3.0, Wi-Fi
Document scanner - desktop
Interface Type
USB 3.0, Wi-Fi
Scanning Sensor Type
Dual CIS
Light Source
RGB LED array
Additional Functions
Email, scan to SharePoint
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple macOS 10.12
29.2 cm x 15.9 cm x 16.8 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.0, Wi-Fi
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Scanner Speed Details
25 ppm - duplex - portrait - A4 - 150 dpi , 25 ppm - duplex - portrait - A4 - 200 dpi , 25 ppm - duplex - portrait - A4 - 300 dpi , 7 ppm - duplex - portrait - A4 - 600 dpi , 25 ppm - duplex - portrait B&W - A4 - 300 dpi , 25 ppm - duplex - portrait B&W - A4 - 400 dpi , 25 ppm - duplex - portrait B&W - A4 - 600 dpi , 7 ppm - duplex - portrait B&W - A4 - 1200 dpi
Scanner Features
One-Button function, Ultrasonic multifeed sensor, Wi-Fi connection only for Android / iOS
Media Handling
Max Document Size
216 mm x 863 mm
Supported Document Size Details
ADF - up to 216 x 863 mm
Automatic
50 sheets
USB 3.0 - Type B
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
20 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
1.6 Watt
Software Included
ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, Nuance Power PDF, Nuance Power PDF Converter (Mac), ScanSnap Sync, ScanSnap Cloud
29.2 cm
15.9 cm
16.8 cm
3 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
CH2V Fujitsu ScanSnap Bag In Stock £41.27
CH2V Fujitsu Extends Warranty From 1 Year to 3 Year For Desktop Scanners - Inc Replacement and Shipping In Stock £63.31
