Outstanding performance starts with reliable, compact hardware technology automatically supported by intuitive routines.
The sleek and compact 40 double sided pages per minute fi-7240 desktop ADF and flatbed scanner from Fujitsu allows for merging paper document content with digitally born data. Enjoy the introduction of optimum quality from automated document capture and increase the breadth of document management related activities such as invoice and forms processing, archiving and workflow. Flexibly fit this document capture solution to existing and emerging tasks such as current mail delivery methods or addressing regulatory concerns.
Efficient scanning
With automatic duplexing and a feeder capacity of 80 sheets, this scanner is designed for efficiency, allowing for quick and easy document processing. -
Versatile performance
Supports a wide range of document sizes and types, including plain paper and plastic cards, ensuring versatile scanning capabilities for various needs. -
High-quality imaging
Features a color depth of 24-bit and a grayscale depth of 8-bit, alongside a maximum optical resolution of 600 DPI, delivering clear and detailed images. -
Advanced features
Equipped with advanced scanning features such as Blank Page Detection, Color Dropout, and automatic color detection, enhancing the scanning process and output quality. -
Energy efficient
ENERGY STAR certified, ensuring efficient power consumption with a nominal voltage of AC 120/230 V and operational power consumption of 38 W.
 - Ricoh fi 7240 - document scanner - desktop - USB 2.0
 - Document scanner - desktop
- Interface Type
 - USB 2.0
- Scanning Sensor Type
 - Triple CCD
- Light Source
 - White LED array
- Max Supported Document Size
 - 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
 - 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
 - 600 dpi x 600 dpi
- Max Document Scan Speed
 - 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
 - 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
 - Plain paper, plastic card
- Document Feeder Type
 - Automatic
- Document Storage Capacity
 - 80 sheets
- Power
 - AC 120/230 V (50/60 Hz)
- System Requirements
 - Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04
 - 57.7 cm x 30 cm x 23.4 cm
 - 8.8 kg
- Environmental Standards
 - ENERGY STAR Qualified
- Interface Type
 - USB 2.0
 - 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
 - 24-bit (16.7 million colours)
 - 600 dpi x 600 dpi
 - Triple CCD
- Bulb / Light Source Type
 - White LED array
- Max Document Scan Speed B/W
 - 40 ppm
- Max Document Scan Speed Colour
 - 40 ppm
- Scanner Speed Details
 - 40 ppm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 40 ppm - greyscale - 200 dpi , 40 ppm - greyscale - 300 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - black & white - 300 dpi , 80 ipm - duplex - colour - 200 dpi , 80 ipm - duplex - colour - 300 dpi , 80 ipm - duplex - greyscale - 200 dpi , 80 ipm - duplex - greyscale - 300 dpi , 80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - black & white - 300 dpi
- Scanner Features
 - Color Dropout, Dynamic Threshold, Error Diffusion, automatic colour detection, automatic page size detection, Simplified DTC, Advanced DTC, Multi-Image Output, Punch Hole Removal, Deskew, Blank Page Detection
 - TWAIN, ISIS
Media Handling
- Max Document Size
 - 216 mm x 5588 mm
- Supported Document Size Details
 - ADF - up to 216 x 355.6 mm , Long document - up to 210 x 5588 mm
 - Automatic
 - 80 sheets
- Interfaces Details
 - USB 2.0 - Type B
 - Directive 2002/95/EC
- ENERGY STAR Certified
- Power Device
 - Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
 - 38 Watt
- Software Included
 - ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
 - 57.7 cm
 - 30 cm
 - 23.4 cm
 - 8.8 kg
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
