Fujitsu fi-7180 Document Scanner
Quicklinx: 9DD3WS00 Mfr#: PA03670-B001
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The fi-7180 document scanner from Fujitsu is armed with a host of automated hardware and software based tools designed to make the job of scanning mixed batches of documents as seamless and hassle free as possible. Impressive scan speeds, industry leading paper protection mechanisms, status monitoring tools and bundled Fujitsu developed driver (PaperStream IP) and image enhancement software (PaperStream Capture) help ensure that the capture of your documents is done reliably and efficiently.
  • Fast and compact
    The fi-7180 has been introduced to support increasingly diverse business related document capture routines at the desktop of individual knowledge workers or small workgroups. Simple, productivity-boosting operation virtually eliminates training requirements.
  • Large volume hopper
    Featuring a high capacity hopper tray, these scanners allow for loading document batches containing up to 80 sheets at a time - and allowing for the continuous feeding of additional documents whilst scanning.
  • High-speed interface
    USB 3.0 support ensures high-speed data transfer between scanner and computer.
  • LCD status display and control panel
    A liquid crystal display (LCD) is included in the operator panel to display useful information including current settings for scanning documents, the number of sheets scanned, and error status. Users know the scanner status in the blink of an eye and can easily select and initiate predefined scanning profiles.
  • iSOP - intelligent Sonic Paper Protection
    Building on and incorporating the market-proven paper protection mechanisms of previous fi-series scanners, the fi-7180 introduces an additional market innovation for safeguarding any paper documents. By listening to the audible sound of paper movements, intelligent Sonic Paper Protection automatically suspends paper feeding if an irregular noise is detected. This advanced Paper Protection feature reliably reduces the risk of damaging documents during scanning.
  • Stable paper feeding with skew reduction
    The fi-7180 is equipped with a "Skew Reducer" to maintain the straight alignment of paper feeding. Particularly valuable for mixed document batches containing small format documents or thin paper sheets, this function reduces the physical skew of documents throughout the paper path. Even the most untidy batches are given special treatment sheet-by-sheet, which ensures total coverage for every scan: no lost data on the edges or in the corners, no more rescans.
  • Less effort for effective, efficient pre-scan processing
    The fi-7180 brings industry leading mixed batch scanning capabilities to the desktop with a design that allows for a record breaking mixed batch feeding range from 27-413 g/m2, freeing the user from most paper weight related pre-sorting requirements. The fi-7180 makes use of an ultrasonic sensor that accurately detects errors where two or more sheets are fed through the scanner at once. Multifeed detection works reliably when scanning mixed batches of documents with different paper weights and sizes. When multifeed is detected, the user is instantly alerted and can continue capturing all relevant sheets and pages without losing relevant information.
Fujitsu fi-7180 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
30 cm x 17 cm x 16.3 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
80 ppm - colour - 200 dpi , 80 ppm - colour - 300 dpi , 80 ppm - greyscale - 200 dpi , 80 ppm - greyscale - 300 dpi , 80 ppm - black & white - 200 dpi , 80 ppm - black & white - 300 dpi , 160 ipm - duplex - colour - 200 dpi , 160 ipm - duplex - colour - 300 dpi , 160 ipm - duplex - greyscale - 200 dpi , 160 ipm - duplex - greyscale - 300 dpi , 160 ipm - duplex - black & white - 200 dpi , 160 ipm - duplex - black & white - 300 dpi
Scanner Features
Built-in LCD screen
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Plain paper
Automatic
80 sheets
Interfaces Details
USB 3.0 - Type B
RoHS
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
42 Watt (1.8 Watt)
Software Included
ScanSnap Manager, Scan to Microsoft SharePoint, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, Error Recovery Guide
30 cm
17 cm
16.3 cm
4.2 kg
5 °C
35 °C
20 - 80% (non-condensing)
9DD3 Fujitsu Assurance Program Silver Extended Service Agreement 3 Years for fi-7x80 In Stock £135.43
9DD3 Fujitsu Extends Warranty From 1 Year to 3 Year For Department Scanners- Inc Replacement and Shipping In Stock £172.59
9DD3 Fujitsu Extends Warranty to 3 Years On-Site Fix for Departmental Scanners - Onsite Within 8 Hours In Stock £523.03
