The fi-7030 is the ideal entry point to professional information capture. It is equipped with PaperStream Capture Version 1.5 that offers a new ergonomic, touch compatible user interface which improves efficiency and interactions across the entire enterprise capture process. The fi-7030 is based on PFU's proven superior image quality technology, combined with improved image processing and capture software, offering everything that users need to start their digital transformation journey.
The fi-7030 captures A4 documents at a speed of 27 double sided sheets per minute (portrait, color, 300 dpi) and can comfortably process mixed batches that can also include embossed cards, long paper scanning of up to 5 meters through the 50 page ADF is also possible as well as A3 documents utilizing an optional carrier sheet.
The scanner additionally makes use of an ultrasonic sensor that accurately detects multifeed errors where two or more sheets are fed through the scanner at once plus intelligent multifeed function that is designed for documents that intentionally feature paper attachments of defined sizes or locations such as sticky notes or photos. The scanner can automatically recognize the location of the attachment and will then exclude that zone from triggering alert conditions.
Should you be scanning mixed batches of differing thicknesses of documents then the "skew reducer" eliminates the risk of physical skew being carried over from one sheet in a mixed batch to the next ensuring that each document is captured with the utmost precision and simplicity. Multi-segmented pick rollers that rotate independently ensure that if a document goes through skewed then this will not affect the alignment of the next document.
The fi-7030 comes with Scanner Central Admin tools that includes functions that system administrators can use to manage the installation and operation of multiple scanners, monitor operating status and update drivers and software from one location. This ability dramatically reduces the cost and work that goes into setting up, operating and maintaining many scanners in an organization and also in expanding the scanner network to multiple locations.
The fi-7030 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture 1.5 introduces detailed scanning routine information next to related profile pictograms, facilitating the capture process and allowing users to choose between fully transparent in-depth details for experts, or simplified easy processing for general users. A new "browse view" functionality, which displays both thumbnails and previews on one screen, enables the user to confirm scanned images during scanning. This saves time when users validate, classify and verify data. Other highlights include the display of batch jobs in process for more transparency and an on-the-fly batch release process. Once users have scanned a batch they can verify the data, alternate orders, collect documents in a joint file, index and automatically release to local or distant repositories, feed workflows, business applications or ECM systems.
Compact design allowing it to be placed anywhere
Its noticeable compact size with a sophisticated design suits various environments. The scanner fits in small spaces even smaller than spaces that are A4 in size on a desk. -
Fast processing performance
The fi-7030 scans at a speed of 27 ppm / 54 ipm (A4, portrait, color, 200 / 300 dpi). The scanner will not make you or your customers wait with a quick startup time of half a second. -
Accurate mixed batch scanning for different types of documents
The Skew Reducer prevents the following documents from being skewed when the preceding document is skewed, thus preventing the image from being incomplete with missing parts even in the case of a batch scan with various types of documents. This also reduces the burden of re-scanning. -
Automatically creates optimal suited image quality without hassle
The PaperStream IP scanner driver, which supports TWAIN / ISIS, avoids the inconvenience of fine adjustments to the settings for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled or soiled documents, or documents with a background pattern.
- Fujitsu fi-7030 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- RGB LED array
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 27 ppm (mono) / 27 ppm (colour)
- Max Document Size
- 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, embossed card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
- 29 cm x 14.6 cm x 13 cm
- 2.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 27 ppm
- Max Document Scan Speed Colour
- 27 ppm
- Scanner Speed Details
- 27 ppm - black & white - A4 - 200 dpi , 27 ppm - greyscale - A4 - 200 dpi , 27 ppm - colour - A4 - 200 dpi , 27 ppm - black & white - A4 - 300 dpi , 27 ppm - greyscale - A4 - 300 dpi , 27 ppm - colour - A4 - 300 dpi , 54 ipm - duplex - black & white - A4 - 200 dpi , 54 ipm - duplex - greyscale - A4 - 200 dpi , 54 ipm - duplex - colour - A4 - 200 dpi , 54 ipm - duplex - black & white - A4 - 300 dpi , 54 ipm - duplex - greyscale - A4 - 300 dpi , 54 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- Multi Color Dropout, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, image merge, Deskew, Blank Page Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 5588 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 17 watt
- Power Consumption Stand by
- 0.15 watt
- Power Consumption Sleep
- 1.1 watt
- Software Included
- Drivers & Utilities, ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 29 cm
- 14.6 cm
- 13 cm
- 2.9 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
