Fujitsu fi-6670 A3 VRS Pro Scanner
Quicklinx: 5GSWWS00 Mfr#: PA03576-B501
The ADF only fi-6670 is amongst the fastest scanners in its class, able to capture documents at 90ppm / 180ipm capable (A4, landscape, 200 dpi). Its 200 sheet document feeder allows continuous scanning containing paper of different weights, quality and sizes and the fi-6670 can even scan paper up to 3 m long enabling digitization of electrocardiograms, instrumental data readings and other long documents.
An extremely compact design with small footprint and operating panel on either side extends options for positioning the scanner in the office.
The fi-6670 comes loaded with features allowing the scanner to work autonomously as a true batch document scanner. Intelligent multi-feed function simplifies pre-scanning preparation and improves efficiency by identifying documents that tend to trigger false multi-feed alerts, such as documents with photos or sticky notes attached. The fi-6670 scans trapezoid-shaped documents across their full width, as well as ensuring that index tab and sticky note attached documents are scanned in their entirety. In addition, the fi-6670 removes the circular and angular punch hole representations that are created from scanning loose-leaf sheets, courier service forms and other similar documents.
Excellent scanning performance is possible with the bundled premium version of ScandAll PRO V2 scanning software, which features embedded zonal OCR functionality, multi-streaming options and a wealth of output format including password protected PDF and PDF/A formats. In daily operation tasks the user can be supported by setting up job routine profiles that can easily be ex- and imported by multiple scan stations. ScandAll PRO V2 Premium features job separation and indexing functionality using 2D codes (matrix codes).
The bundled ScandAll PRO image capture software supports advanced functions such as Automatic Job separation, Indexing, Seamless Microsoft Office SharePoint Server linkage and Scanner Central Admin console for network enabled device management.
The fi-6670 also comes bundled with Kofax Software VRS Professional, which simplifies the image capture operation and streamlines automated business processes. It allows information workers to focus on their productive tasks whilst at the same time supporting them by capturing information from paper documents at the click of a button.
  • Intelligent, reliable production scanning for a more productive work environment
    Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts.
  • High-impact imaging solutions, low environmental impact
    True to Fujitsu's commitment to environmentally responsible manufacturing and design, the fi-6670 business scanner adheres to strict environmental regulations including Energy Star's energy consumption requirements and the EU's Reduction of Hazardous Substances and Volatile Organic Compounds.
Fujitsu fi-6670 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scanning Sensor Type
CCD
Max Supported Document Size
ANSI B (Ledger) (279 x 432 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
279 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
30 cm x 17 cm x 30 cm
17 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
90 ppm - black & white , 90 ppm - colour , 180 ipm - duplex - black & white , 180 ipm - duplex - colour
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
279 mm x 432 mm
Plain paper
Automatic
200 sheets
Interfaces Details
Ultra SCSI - HD-68 , USB 2.0 - Type B
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
216 Watt (6 Watt)
Software Included
Drivers & Utilities, QuickScan (Demo), Adobe Acrobat Standard, ScandAll Pro, Soft IPC (demo)
30 cm
17 cm
30 cm
17 kg
5 °C
35 °C
20 - 80%
Sound Emission
53 dB
