With improving the entire scanning process as its main objective, the fi-6400 production scanner builds upon the qualities that have made Fujitsu the optimal vendor in the mid-volume production market. The fi-6400 incorporates many additional features and functions that will improve your document scanning efficiency. From pure scanning speed, to ease of use to its full suite of software productivity tools, the fi-6400 is the ideal solution for a wide range of production scanning applications.
Large volume hopper and high speed scanning
To boost the efficiency of large volume scanning at centralized operation, up to 500 sheets can be loaded to the hopper at a time. Together with the blazing scanning speed of 100 ppm, maximum productivity can be achieved. -
Advanced feeding mechanism
The fi-6400 is capable of digitizing a variety of document types used in every scenario from ultra-thin receipts to thick document. In addition, this scanner is equipped with reliable paper protection functions to minimize the risk of documents being damaged even during the high speed scanning. -
Remarkable small design
Having a front loading feeding mechanism and low height compact design, the fi-6400 allows operators to perform scanning tasks while sitting at the desk. The scanner is designed to minimize the device's height to allow user to load and remove scanned documents with ease. These greatly reduce the stress of operator who tends to operate for long hours. -
Efficiently manage multiple scanners
Even when installing several scanners, performing the same adjustments to every scanner is unnecessary. Using the bundled Scanner Central Admin, up to 1000 scanners can be managed from one location. In addition, the usage status is traced, so periodic replacement of consumables can be planned and performed smoothly. -
Automatic stacker
Automatic Stacker ensures all your scanned documents tacked neatly and tidily. -
Intelligent multifeed function
The acclaimed intelligent multifeed function simplifies pre-scanning preparation and improves efficiency by ignoring documents that tend to trigger false multifeed alerts, such as documents with intentionally attached photos and sticky notes.
- Fujitsu fi-6400 - document scanner - desktop - USB 2.0 - with NETGEAR ReadyNAS 316 RN31661E
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- White LED array
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 100 ppm (mono) / 100 ppm (colour)
- Max Document Size
- 297 mm x 420 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 500 sheets
- Duty Cycle
- 40000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Windows 8.1
- 46 cm x 43 cm x 31 cm
- 32 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Bundled with
- NETGEAR ReadyNAS 316 RN31661E
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
- Bundled with
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Bulb / Light Source Type
- White LED array
- Max Document Scan Speed B/W
- 100 ppm
- Max Document Scan Speed Colour
- 100 ppm
- Duty Cycle
- Scanner Speed Details
- 100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 85 ppm - portrait - A4 - 200 dpi , 85 ppm - portrait - A4 - 300 dpi , 170 ipm - duplex - portrait - A4 - 200 dpi , 170 ipm - duplex - portrait - A4 - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Intelligent Multi-Feed Function (iMFF), Paper Protection Function, Image Emphasis, Automatic Image Orientation, Error Diffusion, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, built-in LCD screen, Remove Background, Deskew, Long Document Scanning, Background Color Switching
- TWAIN, ISIS
Media Handling
- Max Document Size
- 297 mm x 420 mm
- Plain paper
- Supported Document Size Details
- Long document - up to 297 x 3048 mm
- Automatic
- 500 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Directive 2009/125/EC, RoHS 2011/65/EU
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 200 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 3.2 Watt
- Software Included
- Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 46 cm
- 43 cm
- 31 cm
- 32 kg
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 15 °C
- 35 °C
- 20 - 80% (non-condensing)
