EZVIZ C4W Smart Outdoor Camera with Siren & Strobe Light
Quicklinx: FXG0WS00 Mfr#: CS-CV228-A0-3C2WFR(2.8mm)
Compatible With: Alexa, Google Assistant
  • microSD Card
£71.29 ex VAT
£85.54 inc VAT
Introducing the EZVIZ Full HD Wi-Fi Outdoor Camera This wall-mounted outdoor Wi-Fi camera uses a built-in strobe light and 100db alarm for aiding deterrence, whilst also offering two-way talk and durability in any type of weather. Furthermore, a new EZVIZ feature has been added that allows you to set customisable voice alerts to be activated when motion is detected and help deter suspicious activity, get creative!
Be Informed Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are. Great for outdoor detections in the Garden or Driveway.
Reliable Connectivity Dual antennas built-in the camera ensure reliable wireless transmission indoors or outdoors, to enhance the connection to and from your Wi-Fi Router, removing potential video lagging whilst maintaining good performance through the various weather conditions when placed outside. Amazon Alexa & Google Home Compatible - Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub 24/7 All Season Protection - Because of its IP66 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too.
Two-way Talk Integrated with professional de-noising algorithm to filter background noise for enhanced voice quality. The internal waterproof MIC supports audio pickup within five meters and video recording with sound via the EZVIZ app.
Easy Setup Straight Forward installation with drill template included in the box. The camera itself has a Cardan shaft rotation for various angles, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process. Power cable and mains charger included in the box.
App Features – With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage. Storage of footage - EZVIZ cameras can hold a MicroSD card (up to 128GB) for local continuous storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs) Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
What’s in the box 1x EZVIZ Full HD Wi-Fi Outdoor Smart Home Security Camera Turret 1x Power Adapter with 7.5 Meters total Power Cable 1x Mounting/Drill Template 1x Screw Kit 1x Waterproof Kit 1x Quick Start Guide
  • Active defense with light and sound
    When someone enters protected areas at specific times that you set, the C4W will flash a warning light and play a sound to drive intruders away. Instantly, it pushes a notification to your smartphone, so you can view what's happened and take actions accordingly.
  • Use your own voice to greet or deter visitors
    You may want to remind visitors in a gentle way that they've entered protected area. The C4W lets you create three 10-second audio recordings on the EZVIZ app so that you can protect your property in your own way.
  • Customize motion detection zones
    The C4W camera lets you draw specific zones of interest on the EZVIZ app and adjust motion detection sensitivity to provide just the right amount of security you need.
  • Full HD security, day and night
    Featuring 1080p Full HD resolution, the C4W camera delivers crystal clear monitoring video all day. Plus, a super night vision system allows you to see image details up to 30 meters (98 feet) away in the dark.
  • Save money on bandwidth and storage
    Using the H.265 video compression technology, the C4W renders clearer and smoother video while reducing both the need for bandwidth and data storage space such as microSD cards and the cloud.
  • Dual antennas for enhanced connection
    Boasting wall-penetration and anti-interference capabilities, the C4W stays online better. It has two built-in antennas to ensure a robust and reliable Wi-Fi connection.
  • Braves all types of weather
    The IP67 weatherproofing, dustproof design, and turret housing combine to deliver peace of mind - no matter what the weather is.
EZVIZ C4W - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor - dustproof / waterproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
10.5 cm x 10.5 cm x 9.5 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/2.7"
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Google Assistant, Alexa
Voltage
DC 12 V
Infrared cut filter, Digital Wide Dynamic Range (D-WDR), WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, 3D digital noise reduction (DNR), self-adaptive shutter
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Dome
Wired, wireless
10.5 cm
10.5 cm
9.5 cm
Camera
Colour - Day&Night - fixed - outdoor - dustproof / waterproof
Digital Video Format
H.264, H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
30 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
PS CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Horizontal Field of View (degree)
103
Diagonal Field of View (degree)
118
Network Interface
Ports
LAN
Supported Memory Cards
microSD Card
Screw kit
UL, FCC, RoHS, WEEE, REACH, IP67
Power Requirements
DC 12 V - 1 A
Power adapter 6 Watt
Internet of Things (IoT)
Shipping Width
14.7 cm
Shipping Depth
14.5 cm
Shipping Height
17.3 cm
Shipping Weight
330 g
-30 °C
60 °C
Relative Humidity (operating)
Brand: Ezviz
