TP LINK Tapo C420S2 Outdoor Battery Camera 2-Pack
Quicklinx: H0P2WS00 Mfr#: TAPO C420S2
Type: Outdoor Camera
Compatible With: Alexa, Google Assistant
  • microSD Card
Hurry, only 2 left in stock!
£116.66 ex VAT
£139.99 inc VAT
2K QHD- Now with 1.7 times more pixels than 1080p, providing clearer videos and photos.
180-Day Battery Life - The rechargeable and removable battery with a low-power protocol extends your usage.
Full-Color Night Vision- Reveal high-fidelity details and color at night with the starlight sensor.
Smart AI Detection and Notification- Smart AI indentifies people, pets, packages, and cars, notifying users as needed.
Wire-Free Placement- No wires means you can place the cameras almost anywhere inside or outside-whatever works for you!
Light and Sound Alarm- Triggers sound and light as an alarm when motion is detected.
Two-Way Audio- Enables communication through a built-in microphone and speaker.
Flexible Storage Choices- Save recorded videos on the hub-installed microSD card† (up to 512 GB) or by using Tapo Care** cloud storage services.
IP65 Water&Dust Resistant- Offers excellent waterproof and dustproof performance for outdoor scenarios.
†microSD card needs to be purchased separately.
**Subscribe: https://www.tapo.com/en/tapocare/
  • 180-day long battery life
    The rechargeable and removable battery with low power protocol can largely extend your usage time.
  • 2K QHD crystal clear view
    Now with 1.7 times more pixels than 1080p, providing clearer videos and more crisp photos.
  • Smart AI detection and notification
    Smart AI identifies people, pets, and vehicles, notifying users as needed.
  • Sound and light alarm
    Trigger the sound and light alarm to frighten away the unwanted visitors.
Tapo C420S2 V1 - 2 x Tapo C420 Cameras + Tapo H200 Hub - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - dust resistant / water resistant
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.42 cm x 11.06 cm x 6.42 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Frame Rate (max)
20 frames per second
Motion Detection
Video Modes
2K
Optical Sensor Type
1/3"
Focal Length Control
Fixed focal
Focal Length
3.18 mm
Lens Iris
F/1.61
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
1 - USB adapter , 1 - USB adapter cable , 1 - network cable
Voltage
AC 100-240 V
Smart AI Human Detection, Pet Detection, Vehicle Detection, Push Notification, snapshot function, reset/SYNC button, alarm function, Starlight Technology, Colour Night Vision, customised activity zone, LED indicator
Environmental Parameters (operating)
-20 °C - 45 °C; 10 - 90% RH (non-condensing) relative humidity
Audio Support
Wireless
6.42 cm
11.06 cm
6.42 cm
Camera
Colour - Day&Night - fixed - indoor, outdoor - dust resistant / water resistant
Digital Video Format
H.264
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
2560 x 1440
Frame Rate (max)
Image Sensor
1/3"
Lens Construction
Fixed focal
Focal Length
3.18 mm
Lens Iris
F/1.61
Horizontal Field of View (degree)
113
Network Interface
Network Protocols
TCP/IP, UDP/IP, ICMP, DNS, HTTPS
Screws, mounting template, mounting bracket
1 x USB adapter , 1 x USB adapter cable , 1 x network cable
WPA, WPA2-PSK, UKCA, EAC, Directive 2009/125/EC, Directive 2011/65/EU, Directive 2014/53/EU, Directive 2015/863/EU
Power adapter AC 100-240 V (50/60 Hz)
(up to 180 days)
Internet of Things (IoT)
-20 °C
45 °C
Relative Humidity (operating)
Brand: TP LINK
