eufy Security features a powerful battery that provides long-lasting power for round-the-clock security. To prevent your playful pets from accidentally triggering the motion sensor, you can adjust the sensitivity so that it only triggers when human-sized intruders are detected.
Protection that lasts
The included battery provides ling-lasting power for round-the-clock security. -
Extensive coverage
Detects motion within a 100° radius and up to 30 feet away - more than enough to secure an entire room of your home. -
Protects you, your family, and your privacy
Every eufy Security product is engineered to ensure your data is kept private. Keep a secure record of everything that happens around your home. -
Customizable detection
To prevent your playful pets from accidentally triggering the motion sensor, you can adjust the sensitivity so that it only triggers when human-sized intruders are detected. -
Part of the family
Adding the motion sensor to your existing security system is a breeze. Once installed, pair the device via the eufy Security app. Then, press the button on the motion sensor, and HomeBase will add the sensor to your existing security setup.
- Eufy Security - motion sensor - Wi-Fi - white
- Product Type
- Motion sensor
- Power Source
- Battery
- Connectivity
- Wireless - Wi-Fi
- Adjustments
- Detection sensitivity
- White
- 1-year warranty
- 5.62 cm x 2.2 cm x 5.62 cm
- Product Type
- Motion sensor
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Adjustments
- In app notification
Motion Sensor
- Detection Range
- 9.14 m
- Detection Angle
- 100 degree(s)
- Battery Included
- Required Qty
- 1
- Battery Lifetime
- 2 years
- White
- Warranty
- 1-year warranty
- 5.62 cm
- 2.2 cm
- 5.62 cm
- 70 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 10.5 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 220 g
