Eaton PW9130i3000R-XL2U
Quicklinx: 7GYHWS00 Mfr#: 103006463-6591
The Eaton 9130 Rackmount UPS delivers online power quality and scalable battery runtimes for rack servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of >95%, the 9130 UPS cuts energy costs while packing up to three kVA of power into only 2U of rack space. The 9130 UPS significantly extends battery service life with ABM technology and also has a bright LCD user interface to simplify monitoring.
  • Efficient power management
    The Eaton PW9130i3000R-XL2U UPS ensures your equipment remains operational during power disturbances, thanks to its on-line UPS technology and a robust power capacity of 3000 VA/2.7 kW. Its efficient power management capabilities provide a reliable source of energy.
  • Versatile connectivity options
    Equipped with both RS-232 and USB management interfaces, this UPS offers flexible connectivity options for comprehensive power management and monitoring, ensuring seamless integration with your existing systems.
  • Optimal operating range
    Designed to operate efficiently across a wide temperature range, from 0°C to 40°C, the Eaton PW9130i3000R-XL2U UPS adapts to various environments, ensuring consistent performance and reliability.
  • Advanced monitoring features
    Featuring an LCD display and LED indicators, this UPS provides immediate, easy-to-understand status updates on power conditions and UPS performance, enabling proactive management of your power needs.
  • Compact and convenient design
    With a 2 rack unit height and included rack mounting kit, this UPS is designed for easy integration into standard rack systems, saving valuable space while providing powerful protection for your equipment.
Eaton PW9130i3000R-XL2U - UPS - 2.7 kW - 3000 VA
UPS - rack-mountable
Rack Size
2U
29.5 kg
Input Voltage
AC 220-240 V
Output Voltage
± 3%
Power Capacity
2.7 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid - 54 Ah
Battery Form Factor
Plug-in module
Batteries Qty
6
Run Time (Up To)
14 min at half load
RS-232, USB
43.8 cm x 60 cm x 8.65 cm
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 220-240 V
Input Voltage Range
AC 180 - 276 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
± 3%
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Circuit Protection
Circuit breaker
Efficiency
95%+
Quantity
6
Lead Acid
Voltage Provided
12 V
54 Ah
Run Time (Up To)
14 min at half load , 8 min at 75% load
Recharge Time
3 hours
Maintenance free, sealed
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Communication slot
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
Advance Battery Management (ABM), LCD display, internal bypass, LED indicators, automatic self-test, Remote Emergency Power Off (REPO), hot-swappable batteries
GS, IEC 62040-2, EN 62040-2
Software Included
Eaton Software Suite
Limited warranty - parts and labour - 2 years
5 - 90% (non-condensing)
Sound Emission
44 dB
43.8 cm
60 cm
8.65 cm
29.5 kg
