Your basket is empty
DrayTek Vigor 2925n Dual Ethernet-WAN Router with SSL VPN & WLAN
Quicklinx: 973XWS00 Mfr#: V2925N-K
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11n
Speed: 300Mbps
Rackmount or External: External
  • IEEE 802.11n
Hurry, only 2 left in stock!
£168.98 ex VAT
£202.77 inc VAT
Express delivery Delivered on Tuesday
The Vigor 2925 series is the dual-Ethernet WAN firewall for load-balancing or failover. It's also a fully features firewall, VPN concentrator and content filtering device. This latest router series includes support for professional features such as VLAN tagging, Gigabit Ethernet built-in wireless LAN.
A 5-port Gigabit Ethernet switch on the LAN side provides high speed connectivity for your server, other local PCs or for uplink to a larger Ethernet switch. Comprehensive security features include content filtering, web application controls and an object based firewall management system.
Draytek Vigor 2925n - wireless router - 802.11b/g/n - desktop
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Performance
Firewall throughput: 300 Mbps , VPN throughput (IPSec): 50 Mbps
UPnP sessions: 30 , NAT sessions: 50000 , VPN tunnels: 50 , SSL VPN tunnels: 25
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
DMZ port, IGMP snooping, Syslog support, DoS attack prevention, content filtering, DiffServ support, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), dual WAN connection, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, Multiple SSID support, SMS alert, hidden SSID, DNS proxy, Bandwidth-On-Demand (BOD), IPv4 support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, DHCP client, tagged VLAN, IM/P2P filter, DNS caching, Content Security Management (CSM)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
24.096 cm x 16.507 cm x 4.396 cm
2 years warranty
Enclosure Type
Desktop
Wireless, wired
Performance
PPTP, L2TP, PPPoE
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, R&TTE
Status Indicators
WAN, DMZ, link/activity, USB, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
10 Watt
24.096 cm
16.507 cm
4.396 cm
45 °C
10 - 90% (non-condensing)
Get the most from your Router
973X DrayTek Rack Mount Bracket For Vigor 2830, 2850, 2920, 2930 In Stock £36.27
Speed: 300Mbps
Brand: DrayTek
Price Range Ex VAT: 150 - 300
