The Vigor2920 is firewall broadband routers for connecting to xDSL/cable/VDSL2/Ethernet FTTx. The Gigabit WAN and 4-port Gigabit LAN switch facilitates unified communication applications in business CO/remote site to handle large data from subscribed higher speed broadband. The state-of-art router feature, VPN, security, dual WAN provides integrated benefits for professional users and small offices.
Its well-structured Web User Interface (WUI) offers user-friendly configuration and allows specific setting to satisfy users' various needs. The WUI also provides IP layer QoS (Quality of Service), NAT session/bandwidth management to help users control and allocate the bandwidth on networks.
In short, the WUI of Vigor2920 series give you a nice and smooth way to operate all enrich features you need.
- Draytek Vigor 2920 - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- VPN throughput (IPSec): 40 Mbps
- Capacity
- VPN tunnels: 32
- PPTP, L2TP, NTP, IPSec, PPPoE, DHCP
- Routing Protocol
- RIP-2, static IP routing
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, FTP, TFTP, SSH, CLI
- Firewall protection, DHCP support, VLAN support, Syslog support, SPI, DoS attack prevention, content filtering, dynamic DNS server, E-mail alert, MAC address filtering, VPN passthrough, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, QoS, DPD, IPSec NAT-T, WAN failover, DHCP server, BOD
- 16.5 cm x 24.1 cm x 4.4 cm
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- VPN tunnels: 32
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, AES, IKE, SHA-1
- Authentication Method
- RADIUS, X.509 certificates
- FCC
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- 10 Watt
- 16.5 cm
- 24.1 cm
- 4.4 cm
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90%
Get the most from your Router
DrayTek Rack Mount Bracket For Vigor 2830, 2850, 2920, 2930 | In Stock | £35.00 |
