Vigor 2865 series is a VDSL2 35b/ADSL2+ security firewall router integrating a DSL modem which is compatible with variants of ADSL and VDSL, including profile 35b supervectoring. There is also a Gigabit Ethernet WAN port for broadband connections to share the traffic load or serve as a failover connection. A 3G/4G/LTE USB modem can also be attached to the USB ports of the router. This model features built-in 802.11ac Wave 2 Wi-Fi.
Load balancing
Maximize throughput and reliability by using multiple Internet connections. -
35b supervectoring modem
Integrated VDSL modem supporting VDSL2 profile 35b supervectoring. -
VPN (Virtual Private Network)
Build a secure and private tunnel from the LAN of Vigor 2865 to remote offices and teleworkers over the Internet. -
SSL VPN
The VPN works through firewalls providing secure remote access to any network environment. -
Firewall and content filter
Filter web pages by URL keyword or web category to block access to insecure or inappropriate content. -
Dray DDNS
The DDNS service for you to access the router by a fixed hostname of your choice. -
Wireless WAN
Get Internet access wirelessly from a Wi-Fi network, a mobile hotspot, or a personal hotspot setup on smartphones. -
Hotspot web portal
Market your business and communicate with the guests while offering hospitality Wi-Fi. -
Bandwidth management
Prevent one device using all the bandwidth by bandwidth limit policy, session limit policy, and QoS settings. -
Central AP management
Use the Vigor 2865 router as a wireless controller to maintain and monitor the Vigor APs. -
Central switch management
Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
- Draytek Vigor 2865ac - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 5-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- H.323, ADSL, SIP, ADSL2, ADSL2+, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (SSL): 130 Mbps , NAT throughput: 800 Mbps
- Capacity
- Concurrent SSL VPN tunnels: 16 , Concurrent VPN tunnels: 32 , NAT sessions: 60000 , VLANs supported: 16 , SSIDs per radio: 4
- PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
- Routing Protocol
- RIP, BGP, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
- Firewall protection, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, WDS support, URL filtering, firmware upgradable, WMM support, ACL support, QoS, IPSec NAT-T, WPS, IPSec passthrough, DHCP server, SMS alert, hidden SSID, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, IGMP proxy, 802.1x authentication, ToS, PBC, L2TP passthrough, band steering, WDS bridge, Web Filtering, IGMP fast leave, Airtime Fairness, 2x2 MU-MIMO technology, L2TP over IPSec, client isolation, DMZ support, VLAN Tagging, port-based VLAN, port-based QoS, WDS repeater mode, multiple PVC support, broadcast threshold, DNS filtering, 2x2 MIMO technology, DNSSEC support, WLAN scheduling, DSCP based QoS, Brute Force Protection
- IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.1x, UPnP
- 24.1 cm x 16.6 cm x 4.6 cm
- 620 g
- Localisation
- United Kingdom, Ireland
- Wireless router - 5-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MPPE, AES, SSL, SHA-1, WPA, WPA2, IKEv2, 256-bit SHA, WEP
- Authentication Method
- RADIUS, X.509 certificates, TACACS+, LDAP, XAUTH authentication, SMS passcode
- Status Indicators
- WAN, DMZ, link/activity, USB, DSL, 5 GHz, 2.4 GHz, QoS
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.993.5
- Max Transfer Rate
- 300 Mbps
- LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- 24 Watt
- Cables Included
- 1 x modem cable
- Localisation
- 24.1 cm
- 16.6 cm
- 4.6 cm
- 620 g
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
