DrayTek Vigor 2762 Series ADSL/VDSL Router non wireless
Quicklinx: DJ6QWS00 Mfr#: V2762-K
The Vigor2762 series is VDSL2/ADSL2+ modem/router with Firewall and VPN integrated. It provides 1 RJ-11 WAN port for connecting to DSL line directly, the embedded DSL modem is compatible with all the common VDSL and ADSL modulations. There are also 2 USB ports, to which 3G/4G USB modem can be attached to add backup wireless connectivity.
  • Secure remote access
    Vigor2762 Series is a perfect solution for teleworkers who need a secure remote access to the business network, or for branch offices which need a secures connection to the main office network. It offers 2 concurrent VPN tunnels which are compliant with all the industrial-standard protocols, including IPsec, L2TP over IPsec, and SSL VPN, and comprehensive authentication methods are supported. DrayTek also provides the official license-free VPN client software, the Smart VPN Client.
  • Optimizing bandwidth allocation
    Vigor2762 Series supports bandwidth management that helps you to make the most of out of the limited bandwidth. You may set up Bandwidth Limit or Session Limit to restrict the maximum bandwidth or session number that a host can use, thus to prevent the bandwidth and the router's resources being occupied by a single host. Quality of Service (QoS) allows you to reserve a certain amount of bandwidth for the critical clients or time-sensitive applications, and ensure their connection quality when traffic is heavy. You may classify both inbound and outbound traffic into up to 4 queues, and allocate a certain amount of bandwidth for each of the queues, there is also a simple option for Vigor2762 Series to automatically detect the VoIP traffic and classify them into the additional top priority queue, therefore to ensure good VoIP quality even if the network traffic is busy.
Draytek Vigor 2762 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
VPN tunnels: 2 , IPv4 rules: 20 , IPv6 rules: 40 , IP route policies: 50 , Virtual interfaces (VLANs): 8
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, DHCP, DNS, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, MPOA, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI, TR-069
NAT support, ARP support, IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, ALG support, IPv6 support, QoS, DPD, IPSec NAT-T, RADIUS support, DHCP server, reset button, IPv4 support, 3G/4G USB Dongle Support, DHCP client, tagged VLAN, IGMP proxy, port-based VLAN
IEEE 802.1Q, UPnP
AC 230V
20.7 cm x 13.1 cm x 4.2 cm
440 g
United Kingdom, Ireland
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, SSL, SHA-1, IKEv2
Authentication Method
RADIUS, PAP, CHAP, X.509 certificates, MS-CHAP, MS-CHAP v.2
IEEE 802.1Q, UPnP
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.5 Annex M, ITU G.993.1, ITU G.993.2
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
AC 230V
24 Watt
20.7 cm
13.1 cm
4.2 cm
440 g
45 °C
10 - 90% (non-condensing)
