Devolo Home Control Motion Sensor
Quicklinx: BQYYWS00 Mfr#: 9503
Discreet, alert, smart.
  • Reliably identifies movements of people, animals and objects and sends text*, e-mail or app notifications.
  • Versatile installation via adhesive film or screws (included in the box contents).
  • Continuous brightness measurement, e.g. as feedback to the light controls.
  • Intuitive operation by browser, and a free app for smartphones and tablets.
  • Unobtrusive design for inconspicuous placement.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave® wireless technology.
  • 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack.
The devolo Motion Sensor can be discreetly placed in your smart home and keeps a watchful eye on the surrounding area. It reliably detects every movement in an angle of up to 80 degrees and intelligently distinguishes between people, animals and objects (e.g. a door that moves because of a draft). The devolo Motion Sensor notifies you of the recorded movements via text or e-mail so you can stay informed even when not at home. Your smart home is always safely protected! Thanks to the infrared sensor, the Motion Sensor works just as precisely at night as it does during the day. Its individually configurable light sensor additionally makes it a versatile signal generator for a series of other Home Control components, such as the light controls.
  • devolo makes it easy - making your home into a smart home
    The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution.
  • Easy to retrofit, easy to operate and easy to expand
    devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed.
  • Basic needs for safety, security, comfort, convenience and energy savings as driving forces
    devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
devolo Home Control Motion Sensor - multipurpose sensor - Z-Wave
Multipurpose sensor
Environment
Indoor
Sensor Type
Temperature, motion
Wireless - Z-Wave
Frequency Band
868.42 MHz
2.8 cm x 2.3 cm x 9.6 cm
Multipurpose sensor
Sensor Type
Temperature, motion
Environment
Indoor
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Ubuntu 12.04, Apple MacOS X 10.6 - 10.9, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits)
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
10 m
CR123A
CR123A lithium battery
WEEE
2.8 cm
2.3 cm
9.6 cm
-10 °C
10 - 85% (non-condensing)
