The Dell PowerConnect W-3000 Controller series is a family of three full-featured controllers that addresses a wide range of wireless and wired network mobility, security and remote networking requirements for enterprises of any size. The PowerConnect W-3200 Controller is designed for the small business and branch offices, while the W-3400 Controller is designed for medium/large enterprise or dense office deployments. The W-3000 series is easily installed without disrupting the existing wired network.
The W-3000 series acts as the head-end portion of Dell's wireless LAN architecture, which uses centralized controllers in the data center to manage complex and processing-intensive management and security functions. Edge services are virtualized and implemented in cost-effective PowerConnect W-series access points (APs) at the network edge, which move user traffic to data center controllers through secure IP tunnels over a public or private transport network.
Controller clustering and centralized management allow large enterprise networks with multiple controllers to be managed and maintained with minimal staff overhead. A designated master controller can manage multiple local controllers, or for larger networks, the W-series AirWave Wireless Management Suite (AWMS) provides unprecedented visibility and control for the IT staff.
Hassle-free, dependable deployment
Deploy wireless networks that adjust to how Wi-Fi clients interact. Dell's Adaptive Radio Management technology built into W-series controllers helps ensure maximum client performance while enhancing stability and predictability of the entire Wi-Fi network. Certified for Microsoft Lync, the Dell W-series controllers and access points (APs) offer high-performance, secure and reliable wireless access and management across indoor, outdoor and remote locations. W-series controllers and access points are ideal for organizations seeking to enforce policies and security from a central location and encrypt data from the AP all the way back to the data center, which can also serve as a termination point for your virtual private network (VPN). Dell W-series controllers can be easily installed without disrupting your existing wired network. Maintain HD-quality video and toll-quality voice across your wireless infrastructure with W-series controller-based APs, including 802.11ac and 802.11n APs for both the 2.4 GHz and 5 GHz bands. -
Implement context-aware access policies
Working with Dell W-series access points, the W-series controllers can provide highly detailed and differentiated context-aware policies, including user role, device type, application type, time and location. A context-aware network helps to drastically improve quality of service (QoS) related to real-time unified communications and multimedia traffic, and enhance support for bring your own device (BYOD) environments. -
Centralized wireless mobility control
W-series access points work with any of the W-series controllers to enable high-performance Wi-Fi and secure, flexible management across indoor, outdoor and remote locations in small to very large wireless environments. -
Integrated wireless security
The Dell W-series controllers come with security modules like Wireless Intrusion Protection (WIP), Policy Enforcement Firewall (PEF) and VPN termination capability as well as an enhanced cryptography (ACR) module that offers military-grade cryptographic capabilities. The security module help ensure that no data is sent in the clear and that access-level policies are enforced across entire campuses and all remote users from a single touch point.
- Dell PowerConnect W-3400 - network management device
- Network management device
- Form Factor
- External
- Ports Qty
- 4
- Data Link Protocol
- Performance
- Firewall throughput: 4 Gbps , 3DES throughput: 4 Gbps , AES throughput: 2 Gbps
- Capacity
- Maximum number of access points: 64 , Maximum number of access points (remote): 256 , User licences: 4096 , MAC addresses: 64000 , Active firewall sessions: 128000 , Concurrent IPSec tunnels: 2048 , Virtual interfaces (VLANs): 256 , IPv4 routes (Unicast): 4096 , Maximum number of configured SSIDs: 512
- Power
- AC 90 - 264 V (47 - 63 Hz)
- 35.1 cm x 29.7 cm x 4.4 cm
- 3.2 kg
- 1-year warranty
- 35.1 cm
- 29.7 cm
- 4.4 cm
- 3.2 kg
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wired
- Performance
- Capacity
- Encryption Algorithm
- Triple DES, AES-CCM
- 1 x management (RS-232) - RJ-45 , 4 x 1000Base-T - RJ-45 , 4 x 1000Base-X - SFP (mini-GBIC)
- C-Tick, CISPR 22 Class A, EN 60950, GS, NOM, EN55024, EN55022 Class A, UL 60950, CB, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, MIC, AS/NZS 3548, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, FCC Part 15 A, ANATEL, cTUVus, CAN/CSA C22.2 No. 60065, VCCI Class A, EN 61000-3
- Power Device
- External power adapter
- Voltage Required
- 45 Watt
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
