The DGS-3130 Series switches are Lite Layer 3 Stackable Managed Switches designed to connect end-users in a secure enterprise or metro Ethernet access network. These switches support multicast, and enhanced security, making them an ideal Gigabit access layer solution.
Enhanced network reliability
The DGS-3130 Series targets enterprises and metro Ethernet applications, and customers who require a high level of network security and maximum uptime. The DGS-3130 Series supports an external redundant power supply to ensure continued operation. The models also include reliability features, such as 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP), and 802.1s Multiple Spanning Tree (MSTP), Loopback Detection (LBD), and Broadcast Storm Control, that enhances network resilience. -
Comprehensive security
The DGS-3130 Series provides users with the latest security features such as Multi-layer and Packet Content Access Control Lists (ACL), Storm Control, and IP-MAC-Port Binding (IMPB) with DHCP Snooping. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also define the port number to enhance user access control. With the DHCP Snooping feature, the switch automatically learns IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list. -
Easy access control policies
The DGS-3130 Series supports authentication mechanisms such as 802.1X, Web-based Access Control (WAC), and MAC-based Access Control (MAC) for strict access control and easy deployment. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host. In addition, the switch also supports Microsoft? NAP (Network AccessProtection). NAP is a policy enforcement technology that allows customers to protect network assets from compromised computers by enforcing compliance with network health policies. -
Versatile traffic management
The DGS-3130 Series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Traffic Shaping features guarantee bandwidth for these services when the network is busy. L2 Multicast support enables the DGS-3130 Series to handle growing IPTV applications. Host-based IGMP/MLD Snooping allows multiple multicast subscribers per physical interface and ISM VLAN to send multicast streams in a multicast VLAN to save bandwidth and to provide better security to the backbone network. The ISM VLAN profiles allow users to bind/replace the pre-defined multicast registration information to subscriber ports quickly and easily.
- D-Link DGS 3130-30TS - switch - 30 ports - Managed
- Switch - 30 ports - L3 Lite - Managed - stackable
- Subtype
- Gigabit Ethernet
- Ports
- 24 + 2 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+
- Performance
- Switching capacity: 168 Gbps , Forwarding performance (64-byte packet size): 125 Mpps
- Capacity
- Packet buffer size: 2 MB , Units per virtual stack: up to 32 , IGMP groups: 1024 , Virtual interfaces (VLANs): 4000 , QoS hardware queues: 8
- MAC Address Table Size
- 16384 entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMP, IGMPv2, IGMPv3, MLD, MLDv2, VRRP, static IPv4 routing, static IPv6 routing, RIP-1, RIP-2, RIPng
- Remote Management Protocol
- SSH-2, CLI, Telnet, TFTP, SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2, RMON 3, RMON 9, NTP
- 3 fans, SIM, flow control, HOL Blocking Prevention, MSTP support, RSTP support, STP support, BPDU Filter, Root Restriction, loopback detection, port mirroring, ERPS, IGMP snooping, VLAN Double Tagging (Q-in-Q), MLD snooping, QoS, SP, WRR, bandwidth control, ACL support, Port Security, DHCP snooping, AAA, WAC, EEE, Cable Diagnostics Function, Telnet client, Telnet server, DNS client, system log, sFlow, LLDP support, BOOTP support, DHCP client, DHCP relay, DHCP server, ICMP, proxy ARP, IGMP filtering, MIB II
- IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1w, IEEE 802.1s, IEEE 802.1Q, IEEE 802.1v, IEEE 802.1p, IEEE 802.1x, IEEE 802.3az, IEEE 802.3ah, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 25 cm x 4.4 cm
- 2.98 kg
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16384 entries
- 9KB
- Max Units In A Stack
- 12
- Routing Protocol
- Encryption Algorithm
- SSL, SSL 2.0, SSL 3.0
- Authentication Method
- Secure Shell v.2 (SSH2)
- 24 x 10/100/1000 Base-T , 2 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x 10/100/1000 Base-T RJ-45 console , 1 x 10/100/1000 Base-T RJ-45 management , 1 x USB 2.0 Type A
- Power Device
- Internal power supply - hot-plug
- Power Redundancy
- Optional
- Voltage Required
- 30.76 watt
- MTBF
- 900,546 hours
- FCC Class A certified, VCCI Class A, IC, RCM, BSMI, CCC, CB, cUL
- Software Included
- Standard Image (SI) Software
- 44 cm
- 25 cm
- 4.4 cm
- 2.98 kg
- 0 °C
- 50 °C
- 10 - 90%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 90%
