D-Link 5-Port Gigabit PoE Smart Managed Switch with 1 PD port
Quicklinx: J7KDWS00 Mfr#: DGS-1100-05PDV2
Type: Gigabit Ethernet
Ports: 5
Managed: Yes
POE: PoE
£54.71 ex VAT
£65.65 inc VAT
The DGS-1100 Series is a range of switches designed to meet the requirements of small, medium, and enterprise businesses. Support for multiple PoE standards make the DGS-1100 Series ideal for IP surveillance deployments. Advanced management features, a range of diagnostic and troubleshooting tools, and energy-efficient technologies provide a flexible solution to meet your networking requirements.
  • Gigabit Ethernet speed
    High-speed ports provide the Ethernet technology while retaining backward compatibility for connections to older computers and equipment.
  • Revolutionary energy efficiency
    Innovative D-Link Green features help conserve energy without sacrificing performance so you can reduce operating costs and protect the environment.
  • Smart and flexible management
    Powerful switch management functions can be performed through the web management interface or through a client-based utility.
  • Surveillance VLAN and bandwidth control
    Supports Surveillance VLAN for IP surveillance deployments. This gives video traffic a dedicated VLAN and higher priority through the switch, separating surveillance traffic from the rest of the network.
  • Advanced features
    The switch is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping.
  • Easy troubleshooting
    Features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily.
D-Link DGS 1100-05PDV2 - switch - 5 ports - smart
Switch - 5 ports - smart
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (2 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
18 W
Performance
Switching capacity: 10 Gbps , Forwarding performance: 7.44 Mpps
VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
MAC Address Table Size
2K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 2, ICMP
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, tagged VLAN, DSCP support, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN, 1Mbit packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
15 cm x 9.7 cm x 2.8 cm
840 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
18 W
Performance
2K entries
Routing Protocol
SNMP 2, ICMP
Encryption Algorithm
SSL
Flash Memory
2 MB
Status Indicators
Status, link/activity/speed, PoE, power
5 x 1000Base-T RJ-45 2 ports (PoE) / 1 port Power Delivery
3.24 watt
Power Consumption Stand by
1.728 watt
MTBF
2,357,475 hours
FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
Software Included
D-Link Network Assistant
15 cm
9.7 cm
2.8 cm
840 g
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 5
Managed: Yes
POE: PoE
Brand: D-Link
