D-Link 28-Port Gigabit Ethernet PoE++ Surveillance Switches
Quicklinx: J7LDWS00 Mfr#: DSS-200G-28MPP/B
Hurry, only 1 left in stock!
£455.38 ex VAT
£546.45 inc VAT
The DSS-200G Series is a range of switches designed to meet the surveillance requirements of small, medium, and enterprise businesses.
  • Enhanced connectivity
    With 24 PoE ports and 4 combo SFP ports, the D-Link DSS 200G-28MPP switch offers versatile connectivity options for a variety of network needs, supporting both standard and high-powered devices with a total PoE budget of 518 W.
  • Robust performance
    Boasting a switching bandwidth of 56 Gbps and a forwarding bandwidth of 41.67 Mbps, this switch is engineered to handle substantial data traffic, ensuring smooth and efficient network performance.
  • Advanced network security
    Equipped with SSL encryption and a comprehensive suite of security features including ARP support, DoS attack prevention, and VLAN support, the D-Link DSS 200G-28MPP provides a secure networking environment to protect against threats.
  • Efficient network management
    Manageable via SNMP, ICMP, MIB, and more, this switch offers detailed control over your network, allowing for efficient management and monitoring of network traffic and devices.
  • Durable and reliable
    Designed for longevity with a MTBF of 289,075 hours and equipped with 2 fans for cooling, the D-Link DSS 200G-28MPP is built to withstand demanding network environments, ensuring continuous operation.
D-Link DSS 200G-28MPP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x combo SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
518 W
Performance
Switching bandwidth: 56 Gbps , Forwarding bandwidth: 41.67 Mbps
Packet buffer size: 4.1 Mbit , Virtual interfaces (VLANs): 4094 , VLAN groups: 128 , QoS priority queues per port: 4
MAC Address Table Size
8000 entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, RSTP, STP
Remote Management Protocol
SNMP 2, SNMP, ICMP, MIB
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, QoS, MLD snooping, reset button, Cable Diagnostics Function, LLDP support, DHCP client, built-in DIP switch, tagged VLAN, ONVIF support, ERPS, 2 fans, 6KV Surge protection, Voice VLAN, VLAN management, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, Unknown Storm Control, isolate mode, Green Technology, Asymmetric VLAN, UDP support, TCP support, Auto Surveillance VLAN, PD-Alive
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.3at, IEEE 802.3az, ITU-T G.8032, IEEE 802.3bt
AC 100-240 V (50 - 60 Hz)
44 cm x 33 cm x 4.4 cm
4.71 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
518 W
Performance
8000 entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Encryption Algorithm
SSL
RAM
128 MB DDR3 SDRAM
Flash Memory
32 MB
Status Indicators
Power, alarm, PoE, link/activity/speed
24 x 10/100/1000 Base-T RJ-45 PoE - 90 W , 4 x 1000Base-T SFP , 1 x alarm input RJ-45
Internal power supply
Power Consumption Stand by
15.19 Watt
Rack mounting brackets
Rack Mounting Kit
Included
MTBF
289,075 hours
UL, BSMI, cUL, CB, IC, FCC, LVD
United Kingdom
44 cm
33 cm
4.4 cm
4.71 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
