D-Link DGS-1100 (26-Port) Gigabit Smart Switch
Quicklinx: B8GBWS00 Mfr#: DGS-1100-26
D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
  • Resilience and performance
    The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems.
  • Versatile management
    The EasySmart series can be easily configured through an intuitive, password-protected web-based interface or a PC-based smart console utility. The web interface allows network administrators to remotely control and monitor the switch down to the port level. The SmartConsole utility is a very convenient way to set up a number of EasySmart switches in the same network segment. The SmartConsole utility will automatically discover all available switches and provide instant access, so network deployments can be completed easily and effectively.
D-Link EasySmart Switch DGS-1100-26 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 52 Gbps , Forwarding performance: 38.69 Mpps
QoS hardware queues per port: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP
Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Cable Diagnostics Function, D-Link Green Technology, LLDP support, DHCP client, Energy Efficient Ethernet, loop prevention, 1.5MB packet buffer
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
28 cm x 23 cm x 4.4 cm
1.66 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
HTTP
Encryption Algorithm
SSL
RAM
8 MB
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45 , 2 x SFP
Internal power supply
19.04 Watt
FCC Class A certified, C-Tick, BSMI, cUL, ICES-003, CB, CCC, RoHS, LVD, VCCI Class A
28 cm
23 cm
4.4 cm
1.66 kg
Limited warranty - lifetime
-5 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
B8GB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
