D-Link DES-1018MP 18-Port PoE Fast Ethernet Unmanaged Switch
Quicklinx: B8G6WS00 Mfr#: DES-1018MP
The D-Link DES-1018P/DES-1018MP 18-Port Fast Ethernet PoE Switches with 2 Gigabit Uplink Ports enables users to easily connect and supply power to PoE-capable devices such as wireless access points (APs), network cameras and IP phones. They can also connect other Ethernet devices like computers, printers and network attached storage (NAS) to fit into any type of network application.
  • Power your devices
    It supports IEEE 802.3af Power-over-Ethernet (PoE) to power on your PoE-capable network devices via Ethernet cables without using power adapters.
  • Reliability PoE connections
    Enhanced surge protection on all PoE ports protects the switch when feeding power to outdoor PoE capable devices.
  • Flexible connectivity
    All downlink ports support 10/100M speeds, and two Gigabit uplink ports provide redundant, wired speed connection for reliable networking.
D-Link DES 1018MP - switch - 18 ports - unmanaged
Switch - 18 ports - unmanaged
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
16 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
80 W
Performance
Switching capacity: 7.2 Gbps , Forwarding performance (64-byte packet size): 5.36 Mpps
MAC Address Table Size
8K entries
Flow control, PoE, auto-uplink (auto MDI/MDI-X), store and forward, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
28 cm x 21 cm x 4.4 cm
1.78 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
80 W
Performance
8K entries
Status Indicators
Port transmission speed, power, link OK, link/activity
16 x 100Base-TX RJ-45 PoE - 15.4 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
102.6 watt
MTBF
395,864 hours
FCC Class A certified, cUL, CB, CCC, RoHS, LVD
28 cm
21 cm
4.4 cm
1.78 kg
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
