D-Link 8-Port PoE Gigabit EasySmart Switch
Quicklinx: 9H76WS00 Mfr#: DGS-1100-08P
D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
  • Resilience and performance
    The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems.
  • Versatile management
    The EasySmart series can be easily configured through an intuitive, password-protected web-based interface or a PC-based smart console utility. The web interface allows network administrators to remotely control and monitor the switch down to the port level. The SmartConsole utility is a very convenient way to set up a number of EasySmart switches in the same network segment. The SmartConsole utility will automatically discover all available switches and provide instant access, so network deployments can be completed easily and effectively.
D-Link EasySmart Switch DGS-1100-08P - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, auto-negotiation, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, QoS, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, fanless, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
19 cm x 12 cm x 2.8 cm
710 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
HTTP
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45 PoE - 64 W
External power adapter
7.88 watt
MTBF
708,219 hours
FCC Class A certified, UL, cUL, VCCI Class A ITE, LVD
19 cm
12 cm
2.8 cm
710 g
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
9H76 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
9H76 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
