The DGS-3120 xStack Series switches are enhanced L2 access stackable switches designed to connect end-users in a secure SMB or enterprise network. These switches support physical stacking, multicast, and enhanced security, making them an ideal Gigabit access layer solution.
Standard and enhanced images
The DGS-3120 Series is embedded with two different software images - Standard Image (SI) and Enhanced Image (EI). The Standard Image provides sophisticated features for businesses. It includes advanced Quality of Service (QoS), traffic shaping, L2 multicasting and robust security features. The Enhanced Image supports ERPS, Double VLAN (Q-in-Q), Ethernet OAM, Static Route, IMPB, sFlow, IPv6 features which are suitable for the next generation IPv6 networks or triple play applications in Metro Ethernet. -
Enhanced network reliability
The DGS-3120 Series targets businesses and customers who require a high level of network security and maximum uptime. All the models in DGS-3120 Series support an external redundant power supply so that continued operation can be assured. -
Comprehensive security
The DGS-3120 Series provides users with the latest security features such as Multilayer and Packet Content Access Control Lists (ACL), Storm Control, and IP-MAC-Port Binding (IMPB) with DHCP Snooping. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also define the port number to enhance user access control. With the DHCP Snooping feature, the switch automatically learns IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list. In addition, the D-Link Safeguard Engine identifies and prioritizes "CPU interested" packets to prevent malicious traffic from interrupting normal network flows, and to protect switch operation. -
Identity driven network policies
The DGS-3120 Series supports authentication mechanisms such as 802.1x, Web-based Access Control (WAC), and MAC-based Access Control (MAC) for strict access control and easy deployment. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host. In addition, the switch also supports Microsoft NAP (Network Access Protection). NAP is a policy enforcement technology that allows customers to protect network assets from unhealthy computers by enforcing compliance with network health policies. -
Traffic management for triple play
The DGS-3120 Series implements a rich set of multilayer QOS/CoS features to ensure that critical network services like VoIP, video conference, IPTV and IP Surveillance are served with high priority. The Traffic Shaping features guarantee bandwidth of these services when the network is busy. With L2 Multicast support, the DGS-3120 Series shows its ability to handle growing IPTV applications. Host-based IGMP/MLD Snooping allows multiple multicast subscribers per physical interface and ISM VLAN sends multicast streams in a multicast VLAN to save bandwidth and to provide better security to the backbone network. The ISM VLAN profiles allow system administrators to bind/replace the pre-defined multicast registration information to subscriber ports quickly and easily. -
Proactive, effective network management
To uphold business customers' Service Level Agreements (SLA), service providers must reduce the Mean Time to Repair (MTTR) and increase service availability. Ethernet OAM features address these challenges and enable service providers to offer carrier-grade services. The DGS-3120 Series supports industry-standard OAM tools, including IEEE 802.3ah, IEEE802.1ag, and ITU-TY.1731. Connectivity Fault Management (CFM) provides tools to monitor and troubleshoot end-to-end Ethernet networks, allowing service providers to check connectivity, isolate network issues, and identify customers affected by network issues. -
IPv6 technology
The DGS-3120 Series is fully compliant with the future IPv6 networks. It supports remote IPv6 manageability from telnet, HTTP, or SNMP. To create secure IPv6 networks, the DGS-3120 Series uses IPv6 ACL, DHCPv6 Snooping and Neighbor Discovery (ND) Snooping functions to protect the network from illegal IPv6 clients. The DGS-3120 Series has been certified with IPv6 Ready Logo Phase 2 from the IPv6 forum, a worldwide IPv6 advocacy consortium. The IPv6 Ready Logo Program provides conformance and interoperability of IPv6 products. -
Manageability
D-Link's Single IP Management (SIM) simplifies and speeds up management tasks, allowing multiple switches to be configured from any workstation running a web browser through one unique IP address. This virtual stack is managed as a single object, having all units maintained by one IP address. The DGS-3120 Series also supports standard-based management protocols such as SNMP, RMON, Telnet, Console, Web-based GUI and SSH/SSL security authentication. -
D-Link Green Technology
D-Link is striving to take the lead in developing innovative and power-saving technology that does not sacrifice functionality. The DGS-3120 Series implements the D-Link Green Technology, which includes a power saving mode, smart fan, reduced heat dissipation, and cable length detection. The power saving feature automatically powers down ports that have no link or link partner. The Smart Fan feature allows for the built-in fans to automatically turn on at a certain temperature, providing continuous, reliable and eco-friendly operation of the switch.
- D-Link xStack DGS-3120-48PC - switch - 48 ports - Managed
- Switch - 48 ports - Managed - stackable
- Subtype
- Gigabit Ethernet
- Ports
- 44 x 10/100/1000 + 4 x combo SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 136 Gbps , Forwarding performance (64-byte packet size): 101.2 Mpps
- Capacity
- ACL rules: 1500 , QoS hardware queues: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 13000 bytes
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2, CLI
- Flow control, Layer 2 switching, DHCP support, BOOTP support, ARP support, VLAN support, IGMP snooping, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, ACL support, QoS, Jumbo Frames support, DHCP server, MLD snooping, Safeguard Engine, NAP, D-Link Green Technology
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.3at
- Power
- AC 120/230 V (50 - 60 Hz)
- 44 cm x 31 cm x 4.4 cm
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- Capacity
- 16K entries
- 13000 bytes
- Max Units In A Stack
- 32
- Encryption Algorithm
- SSL, SSL 3.0, SSL 2.0
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Flash Memory
- 32 MB
- 1 x network stack device x 2 , 48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x console - RJ-45 management , 4 x SFP (mini-GBIC)
- Expansion Slots
- 1 (total) / 1 (free) x SD Memory Card
- Power Device
- Internal power supply
- Voltage Required
- Redundant Power System (RPS) connector
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, CB, IC, RoHS
- Software Included
- Standard Image (SI) Software
- 44 cm
- 31 cm
- 4.4 cm
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
