D-Link 24-Port4 PoE SFP Managed Gigabit Switch
Quicklinx: D0WQWS00 Mfr#: DGS-3000-28LP
D-Link 24 PoE ports + 4 SFP ports Managed L2 Metro Ethernet Gigabit Switch.
  • Efficient and resilient networking
    The DGS 3000 series supports surge protection on all Ethernet ports, protecting the switch from power surges due to lightning strikes or faulty electrical cabling.
  • Quality of service
    The DGS 3000 series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Flexible packet classification can be based on various header fields or user-defined packet content to help administrators prioritize network traffic.
  • Identity-driven network policies
    The DGS 3000 series supports authentication mechanisms for strict access control to network resources. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host.
D-Link DGS 3000-28LP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
193 W
Performance
Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 68.45 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH
Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, half duplex mode, full duplex mode, Dying Gasp support, ACL support, QoS, MLD snooping, Safeguard Engine, IPv4 support, LLDP support, RSPAN, CoS, D-Link SIM, ToS, DSCP support, ERPS, 1.5MB packet buffer, ARP inspection, 6KV Surge protection, AAA, VLAN mirroring, WAC, CFM, LLDP-MED, Guest VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ae
44 cm x 21 cm x 4.4 cm
2.54 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
193 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS, TACACS+
Status Indicators
Power, RPS (Redundant Power Supply), fan, console, link/activity/speed
24 x 1000Base-T RJ-45 , 4 x SFP , 1 x console RJ-45 management
MTBF
304,565 hours
VCCI, C-Tick, BSMI, cUL, CB, FCC, IEEE 802.3af, IEEE 802.3at
44 cm
21 cm
4.4 cm
2.54 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
