D-Link 10-Port Gigabit EasySmart Switch 242W PoE
Quicklinx: D0WXWS00 Mfr#: DGS-1100-10MPP
D-Link's DGS-1100 series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras. Advanced management features, diagnostic and troubleshooting tools, and energy efficient technologies provide a flexible solution to suit your networking requirements.
  • Optimized for video surveillance
    The DGS-1100 series supports Auto Surveillance VLAN (ASV) which ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. You can also access in real-time vital information on your surveillance network such as surveillance topology and device status as well as PoE power and network bandwidth utilization.
  • Auto voice VLAN and bandwidth control
    The DGS-1100 series supports Auto Voice VLAN, which are best suited for VoIP deployments. This enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. Bandwidth control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or have high priority.
  • Advanced features
    DGS-1100 series is equipped with advanced security features such as Static MAC, storm control, and IGMP snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
  • Easy troubleshooting
    The DGS-1100 series features loopback detection and cable diagnostics to help network administrators find and solve network problems quickly and easily. Loopback detection is used to detect loops created by a specific port and automatically shut down the affected port. The cable diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
  • Easy to deploy
    The DGS-1100 series supports an intuitive D-Link network assistant utility and a web-based management interface. The D-Link network assistant utility allows customers to discover all switches in the D-Link Smart Managed Switch family within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, which also makes the initial setup of the Smart Managed Switches quick and easy. Switches within the same L2 network segment that are connected to the user's PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The graphic web-based management interface provides a user-friendly interface that enables network administrators to remotely control their network down to the port level.
D-Link DGS 1100-10MPP - switch - 10 ports - smart - rack-mountable
Switch - 10 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
242 W
Performance
Switching capacity: 20 Gbps
VLAN groups: 128
MAC Address Table Size
16K entries
VLAN support, Quality of Service (QoS), bandwidth control, D-Link Green Technology, LACP support, Energy Efficient Ethernet, universal power over Ethernet (UPOE), 6KV Surge protection
IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3bt (draft)
28 cm x 18 cm x 4.4 cm
1.98 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
242 W
Performance
VLAN groups: 128
16K entries
Flash Memory
16 MB
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-X SFP
Internal power supply
Power Provided
253 Watt
MTBF
1,719,951 hour(s)
VCCI, BSMI, CCC, IC, FCC
28 cm
18 cm
4.4 cm
1.98 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
