Get exceptional performance, faster connection, and wider coverage on your mobile devices. The WAP571 access point has built-in controller software for managing multiple access points. Its intuitive web-bases configuration allows you to set it up in just minutes.
CONNECTIVITY
Provides cost-effective 802.11ac Wave 1 connectivity with speeds up to 1.9 Gbps and uses a concurrent dual-band radio for improved coverage and user capacity -
TECHNOLOGY
Supports 3x3 multiple-input multiple-output (MIMO) technology with three spatial streams for maximum performance on both 2.4- and 5.0-GHz radios -
POWER OVER ETHERNET
Dual Gigabit Ethernet LAN with PoE support, and link aggregation -
GUEST WIFI
Provides secure guest access with multiple authentication options; supports social media login such as Google and Facebook -
PROTECTION
Cisco Umbrella integration protects wireless devices from malware and phishing
- Cisco Small Business WAP571 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Arab Emirates, South Africa, Vietnam, Hong Kong, Thailand, United Kingdom, Europe, Turkey
- RAM
- 256 GB
- Flash Memory
- 128 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Connection / user qty: 200 , Concurrent users per radio: 50 , Maximum number of access points (per cluster): 16 , Maximum number of configured SSIDs: 16
- Included Accessories
- Wall/ceiling mounting plate
- Power Over Ethernet (PoE) Supported
- PoE+
- 23 cm x 23 cm x 4 cm
- 778 g
- Limited lifetime warranty
- 23 cm
- 23 cm
- 4 cm
- 778 g
- Localisation
Processor / Memory / Storage
- RAM
- 256 GB
- Flash Memory
- 128 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.9 Gbps
- Spread Spectrum Method
- OFDM, DSSS
- NTP, DHCP, Bonjour
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
- Status
- Auto-sensing per device, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, DFS support, Wireless Distribution System (WDS) support, firmware upgradable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, wireless bridge mode, reset button, IPv4 support, 3T3R MIMO technology, rogue access point detection, DHCP client, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 802.1x authentication, Link Aggregation, network diagnostics, SSID to VLAN mapping
- Encryption Algorithm
- WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 6
- 1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (management) - RJ-45
- Cables Included
- 1 x network cable
- ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EMI, EN 300 328, EN 301 489-1, AS/NZS 4268.2003, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE+
- 18 Watt
- OS Provided
- Linux
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
