Meraki MR20 Clound Managed Access Point
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQR
Quicklinx: DV8MWS00 Mfr#: MR20-HW
  • IEEE 802.11n
£140.76 ex VAT
£168.91 inc VAT
The Cisco Meraki MR20 is a dual-radio, cloud-managed 2x2:2 802.11ac Wave 2 access point with MU-MIMO support. Designed for basic, very low-density deployments, the MR20 provides enterprise grade security and simple management.
The MR20 is managed through the Meraki cloud, with an intuitive browser-based interface that enables rapid deployment without training or certifications. Because the access point is monitored 24x7 by the Meraki cloud, the MR20 can deliver real-time alerts if the network encounters problems, and diagnostic tools enable real-time troubleshooting over the web. The MR20's firmware is always kept up to date from the cloud. New features, bug fixes, and enhancements are delivered seamlessly over the web, meaning no manual software updates to download or missing security patches to worry about.
  • Aggregate data rate of up to 1.3 Gbps
    A 5 GHz 2x2:2 radio supporting 80 MHz channel widths and a 2.4 GHz 2x2:2 radio supporting 40 MHz channel widths offer a combined dual-radio aggregate frame rate of 1.3 Gbps, with up to 866 Mbps in the 5 GHz band thanks to 802.11ac Wave 2 and 400 Mbps in the 2.4 GHz band.
  • Multi User Multiple Input Multiple Output (MU-MIMO)
    With support for the 802.11ac Wave 2 standard, the MR20 offers MU-MIMO for more efficient transmission to multiple clients. This increases the total network performance and improves the end-user experience.
  • Integrated enterprise security and guest access
    The MR20 features integrated, easy-to-use security technologies to provide secure connectivity for employees and guests alike. Advanced security features such as AES hardware-based encryption and WPA2-Enterprise authentication with 802.1X provide wire-like security while still being easy to configure. One-click guest isolation provides secure, Internet-only access for visitors.
  • Secure wireless environments using Air Marshal
    The MR20 comes equipped with Air Marshal, a built-in wireless intrusion prevention system (WIPS) for threat detection and attack remediation. MR20 access points will scan their environment opportunistically based on user-defined preferences. Alarms and auto-containment of malicious rogue APs are configured via flexible remediation policies, ensuring optimal security and performance in even the challenging wireless environments.
  • Application-aware traffic shaping
    The MR20 features an integrated Layer 7 packet inspection, classification, and control engine, enabling you to set QoS policies based on traffic type. Prioritize your mission-critical applications, while setting limits on recreational traffic, e.g., peer-to-peer and video streaming.
  • Self-configuring, self-optimizing, self-healing
    When plugged in, the MR20 automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. It self-optimizes, determining the ideal channel, transmit power, and client connection parameters. And it self-heals in the event of a switch or cable failure by meshing with nearby Meraki access points, providing continued gateway.
  • Integrated analytics
    Drill down into the details of your network usage with highly granular traffic analytics. Extend your visibility into the physical world with built-in location analytics that enables you to view visitor numbers, dwell time, repeat visit rates, and track foot traffic trends.
Cisco Meraki MR20 - radio access point - Wi-Fi 5 - cloud-managed
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 12 V
20.2 cm x 12.4 cm x 2.58 cm
272 g
Radio access point
20.2 cm
12.4 cm
2.58 cm
272 g
External
Wireless
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
IPSec
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, Boot State, status
Hardware encryption, firmware upgradable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), 2T2R MIMO technology, Maximum Ratio Combining (MRC), Wireless Intrusion Prevention System (WIPS), tagged VLAN, security lock slot (cable lock sold separately), DiffServ Code Point (DSCP) support, Unscheduled Automatic Power Save Delivery (U-APSD), beamforming technology, PMK Caching, opportunistic key caching (OKC)
Encryption Algorithm
AES, TKIP, WPA, WPA2-PSK, WPA2-Enterprise, WEP, EAP-SIM
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11r
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45
ICES-003, EN55024, FCC Part 15 B, RSS-102, FCC Part 15 C, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC Part 15 E, EN 62311, EN 300 328, EN 50385, LP0002, RSS-247, EN 301 489-1-17, EN 62479, EN 301 893, CISPR 32, EN 55032, CAN/CSA-C22.2 No. 60950-1, EMI Class B, AS/NZS 2772
PoE
DC 12 V
11 Watt
Limited warranty - advance parts replacement - lifetime
5 - 95% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac Wave 2
Brand: Meraki
