The Cisco Aironet 1815w access point offers a compact, wall plate mountable access point, ideal for hospitality, cruise ships, residential halls, or other multiple-dwelling-unit deployments. Packing 802.11ac Wave 2 wireless standards support and Gigabit Ethernet wired connectivity into a sleek device, the 1815w is built to take full advantage of existing cabling infrastructure while blending into the visual footprint. This combination provides high performance while reducing total cost of ownership.
MU-MIMO
802.11ac Wave 2 with 2x2:2 MIMO technology uses two spatial streams when operating in SU-MIMO or MU-MIMO mode, offering 867 Mbps rates for more capacity and reliability than competing access points -
APPLICATION VISIBILITY AND CONTROL
Network Based Application Recognition (NBAR) deep-packet inspection technology provides application-aware control on a wireless network and enhances manageability and productivity. It also extends Cisco's Application Visibility and Control (AVC) as an end-to-end solution, which gives a complete visibility of applications in the network and allows the administrator to take some action on the same -
RADIO RESOURCE MANAGEMENT
Cisco's Radio Resource Management (abbreviated RRM) allows Cisco's Unified WLAN Architecture to continuously analyse the existing RF environments, automatically adjusting each AP's power and channel configurations to help mitigate things such as co-channel interference and signal coverage problems. RRM reduces the need to perform exhaustive site surveys, increases system capacity and provides automated self-healing functionality to compensate for RF dead zones and AP failures -
SECURITY
Securing the Device: Cisco Umbrella (OpenDNS), Identity PSK (iPSK), IP and DNS ACLs. Securing the Air: Spectrum Intelligence, Wireless Intrusion Detection (WIDS). Securing the Network: 802.1x on AP, AAA profiling and policy -
PEACE OF MIND
1-year limited hardware warranty
- Cisco Aironet 1815W - radio access point - Bluetooth, Wi-Fi 5
- Radio access point
- Form Factor
- In-wall mountable
- Processor
- 710 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.1, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Mounting brackets, Torx security screw
- Power Over Ethernet (PoE) Supported
- PoE
- 8.9 cm x 14 cm x 3.15 cm
- 280 g
- Limited lifetime warranty
- 8.9 cm
- 14 cm
- 3.15 cm
- 280 g
Processor / Memory / Storage
- Processors Installed
- 710 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Form Factor
- In-wall mountable
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Port status, Boot State, error, status
- VLAN support, Wi-Fi Multimedia (WMM) support, 2T2R MIMO technology, Maximum Ratio Combining (MRC), 802.1x authentication, cyclic shift diversity (CSD), MU-MIMO technology, WPA encryption, packet aggregation A-MPDU, packet aggregation A-MSDU, SU-MIMO technology, dual band, Dynamic Frequency Selection (DFS)
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- RADIUS, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.3at, Bluetooth 4.1, IEEE 802.11r, IEEE 802.11ac Wave 2
Aerial
- Antenna
- Internal
- 2 x 1000Base-T (PoE) - RJ-45 , 1 x console - RJ-45 , 1 x pass-through - RJ-45 , 2 x 1000Base-T - RJ-45
- VCCI, ICES-003, FCC Part 15.247, RSS-102, UL 2043, AES, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, ARIB STD-T66, ARIB STD-T71, EN 300 328, FCC OET Bulletin 65c, EN 301 489-1, RSS-247, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE
- 8.5 Watt
- Limited warranty - advance hardware replacement - lifetime - response time: 10 days
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
