Cisco Small Business WAP581 - Radio access point - 802.11ac
Quicklinx: FVVVWS00 Mfr#: WAP581-E-K9
  • IEEE 802.11n
£227.02 ex VAT
£272.42 inc VAT
Today Wi-Fi is the primary way for mobile access; small to medium-sized businesses are looking for simple, yet easy-to-deploy Wi-Fi networks where they can provide excellent experience to their employees and customers. To stay productive, they need dependable, business-class access to network applications throughout the office. The Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN provides a simple, cost-effective way to extend highly secure, high-performance mobile networking to your employees and guests, so they can stay connected anywhere in the office, regardless of what mobile devices they use. The Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN uses concurrent dual-band radio for improved coverage and user capacity. The 4 x 4 MU-MIMO technology on the 5 GHz radio and 3 x 3 MIMO on the 2.4 GHz radio allow the access point to run at maximum performance and deliver better user experience. Two Gigabit Ethernet LAN interfaces, one with 2.5 Gigabit Ethernet and the second with 1 Gigabit Ethernet with PoE facilitate flexible installation and reduce cabling and wiring costs. Intelligent quality-of-service (QoS) features let you prioritize bandwidth-sensitive traffic for voice-over-IP (VoIP) and video applications. To provide highly secure guest access to visitors and other users, Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN supports a captive portal with multiple authentication options and the ability to configure rights, roles, and bandwidth. A customized guest login page lets you present a welcome message and access details, and reinforces your brand with company logos.
  • CONNECTIVITY
    Provides cost-effective 802.11ac Wave 2 connectivity with speeds up to 2.8 Gbps and uses a concurrent dual-band radio for improved coverage and user capacity
  • TECHNOLOGY
    Supports 4 x 4 multi-user multiple-input, multiple-output (MU-MIMO) technology on a 5.0-GHz radio and 3 x 3 MIMO technology on a 2.4-GHz radio for maximum performance
  • POWER OVER ETHERNET
    Dual Gigabit Ethernet (2.5 G and 1 G) LAN with PoE support, and link aggregation
  • GUEST WIFI
    Provides secure guest access with multiple authentication options; supports social media login such as Google and Facebook
  • PROTECTION
    Cisco Umbrella integration protects wireless devices from malware and phishing
Cisco Small Business WAP581 - radio access point - Wi-Fi 5
Radio access point
External
Saudi Arabia, South Africa, Vietnam, Hong Kong, Thailand, United Kingdom, Europe, Turkey
RAM
256 GB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
VLANs supported: 32 , Connection / user qty: 200 , Concurrent users per radio: 50 , Maximum number of access points (per cluster): 16 , Maximum number of configured SSIDs: 16
Wall/ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
22.9 cm x 22.9 cm x 3.8 cm
1.4 kg
Radio access point
22.9 cm
22.9 cm
3.8 cm
1.4 kg
Processor / Memory / Storage
RAM
256 GB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
2.8 Gbps
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
NTP, DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Load balancing, VLAN support, Syslog support, IPv6 support, firmware upgradable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, 3T3R MIMO technology, rogue access point detection, DHCP client, Energy Efficient Ethernet, e-mail notification, 4T4R MIMO technology, security lock slot (cable lock sold separately), 802.1x authentication, VoIP support, Link Aggregation, Wireless Scheduler, Dynamic Frequency Selection (DFS)
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
1 x 2.5 GBase-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45
1 x network cable
ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EMI, EN 300 328, EN 301 489-1, AS/NZS 4268.2003, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE+
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 2.8Gbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Brand: Cisco
