Cisco Aironet Dual Band Radio Access Point
Quicklinx: B20VWS00 Mfr#: AIR-CAP1702I-E-K9
  • IEEE 802.11n
If you operate a small or medium-sized enterprise network, deploy the Cisco Aironet 1700 Access Point for 802.11ac Wi-Fi technology at an attractive price. The Aironet 1700 Series meets the growing requirements of wireless networks by delivering better performance than 802.11n and providing key RF management features for improved wireless experiences. The 1700 series supports a theoretical connection rate of up to 867 Mbps.
  • Robust security
    Equipped with advanced encryption algorithms including AES, PEAP, TKIP, TLS, TTLS, WPA, and WPA2, this wireless access point ensures secure and private data transmission, safeguarding sensitive information against unauthorized access.
  • Enhanced connectivity
    Featuring 3T3R MIMO technology and supporting multiple Wi-Fi bands (2.4 GHz and 5 GHz), the device offers improved data rates up to 867 Mbps, ensuring high-speed Internet access for multiple devices simultaneously.
  • Optimized performance
    Incorporates Cisco's technologies such as CleanAir Express, BandSelect, and VideoStream, enhancing wireless performance while minimizing interference and optimizing multimedia traffic delivery.
  • Comprehensive standards support
    Complies with a wide range of IEEE standards including 802.11a/b/g/n/ac (draft 5.0), 802.1x, 802.3af, and 802.3at, making it a versatile solution for various networking environments.
  • Efficient management
    Features such as radio resource management (RRM), rogue access point detection, and roaming function enable efficient management of wireless networks, ensuring reliable and consistent connectivity.
Cisco Aironet 1702i Controller-based - radio access point - Wi-Fi 5
Radio access point
External
Belgium, Bahrain, Lebanon, Oman, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Estonia, Lithuania, Mongolia, South Africa, Vietnam, Ukraine, Iceland, Romania, Sri Lanka, Luxembourg, Hungary, Cyprus, Iraq, Ghana, Kenya, Nigeria, Jamaica, Algeria, Liechtenstein, Gibraltar, Malta, Monaco, Tunisia, Croatia, Slovakia, Slovenia, Latvia, Libya, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland, Serbia, Montenegro, Bosnia and Herzegovina
RAM
512 MB
Flash Memory
64 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 5.0)
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
22.1 cm x 22.1 cm x 5.1 cm
1 kg
Radio access point
22.1 cm
22.1 cm
5.1 cm
1 kg
Enclosure Colour
Grey
Processor / Memory / Storage
RAM
512 MB
Flash Memory
64 MB
External
Wireless
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Auto-sensing per device, DFS support, Wi-Fi Multimedia (WMM) support, roaming function, Maximum Ratio Combining (MRC), 3T3R MIMO technology, Transmit Beam-forming (TxBF) ready, rogue access point detection, plenum-rated, CleanAir Express technology, Cisco BandSelect technology, Cisco VideoStream technology, radio resource management (RRM), cyclic shift diversity (CSD)
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac (draft 5.0)
Aerial
Antenna
Internal
Directivity
Omni-directional
Gain Level
4 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, ICES-003, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, Directive 93/42/EEC, EN 300 328, EMI/EMS Class B, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE
15 Watt
Limited warranty - advance parts replacement - lifetime - response time: 10 days
10 - 90% (non-condensing)
B20V C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B20V C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
