For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your PC's networking capabilities, ideal for high-speed Internet, streaming, and gaming. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection that resists corrosion, ensuring your network setup remains uninterrupted. -
Universal compatibility
Featuring a T568B wiring scheme and male RJ-45 connectors on both ends, this network patch cable is compatible with a wide range of devices and networks. Its universal design makes it a versatile addition to any networking setup, supporting seamless integration with your existing infrastructure.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - purple
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Purple
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 5 m
 - Purple
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
