For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transmission for your computing needs. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket material, this patch cable is built for durability and long-term use. The gold-plated connectors also provide a reliable connection and resist corrosion. -
Universal compatibility
Featuring a T568B wiring scheme and RJ-45 connectors, this cable is compatible with a wide range of devices, ensuring a versatile solution for your networking requirements.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - pink
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Pink
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 5 m
 - Pink
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
