For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring a reliable connection and long-lasting performance for all networking needs. -
Enhanced performance
With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it suitable for various applications, including video streaming, high-speed Internet, and server connections. -
Universal compatibility
Featuring RJ-45 male connectors on both ends and complying with T568B wiring schemes, this network cable ensures compatibility with a wide range of devices, facilitating easy integration into existing networks.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - pink
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 3 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Pink
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 3 m
 - Pink
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
