For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, whether at home or in the office. -
Durable design
Constructed with a PVC jacket and 24 AWG wire, this patch cable is built for durability and long-term use. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring a consistent and quality connection over time. -
Universal compatibility
Featuring a T568B wiring scheme and RJ-45 connectors, this cable is compatible with a wide range of devices and networks. It's designed to meet the requirements of PC environments, making it a versatile choice for various networking setups.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - green
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 3 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Green
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 3 m
 - Green
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
