For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with gold-plated RJ-45 connectors on both ends, ensuring a high-quality connection that minimizes interference and maximizes performance for reliable data transfer. -
Durable design
Featuring a robust PVC jacket material and an American Wire Gauge (AWG) of 24, this patch cable is built to withstand the rigors of daily use, ensuring long-lasting performance and durability. -
High-speed performance
Tested to support frequencies up to 350 MHz, this network patch cable is capable of delivering efficient data transmission rates, making it suitable for various networking environments, from home offices to large data centers.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - brown
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Brown
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 3 m
- Brown
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
