For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing signal quality for optimal network performance. -
Durable design
Designed with a robust PVC jacket and an American Wire Gauge (AWG) of 24, this network patch cable is built to withstand the rigors of daily use. Its durability ensures a long-lasting solution for networking needs, whether at home or in the office. -
High-speed performance
Supporting tested frequencies up to 350 MHz, this CAT 5e cable facilitates high-speed data transmission. It's ideal for supporting complex networking setups requiring high bandwidth, from video conferencing to cloud computing.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - black
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 3 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
