For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
Enhanced connectivity
Featuring gold-plated RJ-45 connectors, this CAT 6 patch cable ensures a secure and corrosion-resistant connection, enhancing signal clarity and reliability for high-speed network performance. -
Durable design
Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the risk of fire and emits lower levels of toxic smoke in the event of a fire, providing a safer environment while maintaining performance. -
Advanced cable features
Boasting minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is engineered to deliver cleaner signal transmission, reducing packet loss for dependable network connectivity.
 - C2G patch cable - 50 cm - grey
 - Patch cable - CAT 6
- Technology
- Wires per Cable
 - 8 wires
 - Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
- Length
 - 50 cm
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Grey
 - Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
 - Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
 - 24
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
- Length
 - 50 cm
 - 32 g
 - Grey
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS, TIA/EIA-568-B.2
