Powerline adapters are the ideal way of creating a home network or complementing an existing Wi-Fi connection. By providing a secure high speed connection and great service quality, powerlines allow you to watch Standard and High Definition (HD) movies as well as play online games without interruption or pixilation; share photos, music and other media stored on a PC or compatible storage device anywhere in your home. Powerline Adapters will help you reach those areas of your home where Wi-Fi signal is either too weak or cannot reach. Other usages of Powerline adapters include IP-CCtv surveillance cameras, setting up an office network without the need to add more wires or rewire if you change your office configuration.
High speed data transmission
Supports speeds of up to 200Mbps. This can easily satisfy applications such as video, gaming, digital music, file sharing, and Internet browsing in the home.
DS2 Compatible
This product is compatible with all other DS2 powerline adapters - it isn't compatible with the "Homeplug" adapters.
No Extra Wires Needed
Every home has its own power line network. Users don't have to use extra cable for network connection in their home.
Plug & Play
To make a network connection in the home, users just plug the adapters into the outlets without configuring any settings.
Extends connecting range and eliminates dead spots
Unlike wireless technology, the Powerline technology can cover in excess of 99% of the home.
More outlets than other wired solutions
It's more convenient to make the connection in the home. On average, there are 45 outlets in a home, while; MoCA (over coaxial) and HPNA (over phone line) only have around 3-5 outlets.
- LED - Status (multi-color);Ethernet (green): AP (Yellow)
- Button - On/SBY; CONFIG/F RESET
- Interface - RJ-45 X 1 for Ethernet connection + a AC power plug
- Ethernet - Standard IEEE 802.3, IEEE 802.3u - 10/100 BaseT Auto-sense
- MDI/MDX support Yes
- Modulations - OFDM, 1536 Carriers - Flexible frequency configuration
- Data Rate - Up to 200Mbps
- Management - HTTP Web-based management; Firmware upgrade via TFTP
- Security - Mixed DES/3DES encryption guarantees total data security
- Network Protocols - 802.1D Ethernet Bridge Yes - 802.1Q VLAN Yes - Quality of Service (QoS) Yes
- Low Pass Filter - Attenuation> 35 dB at 2M Hz; >80 dB at 30M Hz
- Power - Input: 110-240 VAC, 50/60 Hz; Output AC fuse 4A
- Environment Conditions - Operating temperature 0 ~ 40 degrees Celsius - Relative humidity 0 ~ 90% (non-condensing)
- Dimensions - 65 mm (W) x 40 mm (H) x 132 mm (L)
- Certifications - FCC, CE, UL
What's in the box?
The following items are included in your PG9020 package:
- A pair of PG9020 adapters
- One Ethernet cable
- One copy of this user guide
Fair Usage policy Please note that for BT employees purchasing this product at the employee price there is a limit of 5 per employee
Please Note: Specifications are subject to change without notice.
Resources
The following resources are available for the BT Comtrend Powerline HD Ethernet Female Kit
Customer reviews
Write a review for the BT Comtrend Powerline HD Ethernet Female Kit here!
Two's company, three's a problem...
Reviewed by Paul. Review Posted 25/11/2008
These are fine if you just have two of them as they autoconfigure, but adding more than this is a problem. I found some instructions involving pressing the buttons on the front panel, but these were useless. Its best to plug the new unit directly into a hub, point browsers at both it and an already working unit, and cut and paste the network ID. You can then disconnect from hub and deploy elsewhere in the home.
Overall
Ease of use
Value for money
plug and play, brillian
Reviewed by Anonymous Review Posted 07/03/2008
so easy, get out of box, plug into the wall, computer and hub and off you go. So fast too. Makes Broadband really fast instead of relying on wireless. Brilliant. Buying 2nd pair now.
Overall
Ease of use
Value for money
Works well
Reviewed by Alan. Review Posted 30/10/2008
This came with the BT Vision box and worked well. Like someone said above there weren't many instructions and I thought it wasn't working to begin with but it was my mistake. Just about to start a trial for BT of their new 24Mb Broadband service so it'll be interesting to see if they work as well with that.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
