Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
Your powerful multi-media center
4K screens are becoming increasingly affordable. What happens next? 8K technology is already in the starting blocks with correspondingly high-resolution streaming opportunities that require very fast data transmission. -
HD-streaming
When you download a film, you don't want to wait a long time - and when you stream a film in HD resolution, it shouldn't constantly lag. -
Cloud gaming
If you game online and want to use the opportunities provided by cloud gaming, you need a fast, stable internet connection.
- devolo Magic 2 LAN triple - bridge - wall-pluggable
- Bridge
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
- Auto-uplink (auto MDI/MDI-X), reset button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- 7.2 cm x 4.1 cm x 14.3 cm
- System Requirements
- Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
- 3-year warranty
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Powerline
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- 5 Watt
- Cables Included
- Network cable - 2 m
- OS Required
- 7.2 cm
- 4.1 cm
- 14.3 cm
- Shipping Width
- 19 cm
- Shipping Depth
- 11.8 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 470 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Devolo Magic 2 LAN TRIPLE Add-On Adapter (3x LAN, Pass-Thru)
