Get the job finished immediately by printing on the go with the PJ-662.
Easily carry this compact printer with you to meetings and appointments or keep it mounted in your vehicle – whichever's better suited to your line of work. You can also take your pick from a range of software features and accessories for a fully tailored print solution.
Connect via Bluetooth, IrDA or USB wherever you are. Plus the PJ-662's thermal printing system mean you're guaranteed great results no matter the conditions.
Effortless connectivity
With both IrDA interfaces and wireless capabilities, the Brother PocketJet 6 PJ-662 ensures seamless connection to your devices, making it an ideal solution for on-the-go printing needs. -
Compact and portable
Designed for mobility, this personal printer boasts a lightweight, portable frame, enabling professionals to print high-quality documents anywhere, anytime. -
High-quality monochrome output
Leverage the direct thermal printing technology for sharp, black and white documents with a maximum resolution of 203 x 200 DPI, perfect for all your professional printing requirements. -
Versatile media handling
The Brother PocketJet 6 PJ-662 accommodates a variety of media sizes including A4 and types such as plain paper and continuous forms, offering flexibility for your printing tasks.
- Brother PocketJet 6 PJ-662 - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 473 g
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 6 ppm - B/W
- Max Resolution (B&W)
- 203 x 200 dpi
- Interface
- USB, Bluetooth, IrDA
- Media Type
- Plain paper, continuous forms
- Networking
- Print server - Bluetooth 2.0 EDR
- System Requirements
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- 1-year warranty
- 25.5 cm x 5.5 cm x 3 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 6 ppm - B/W
- Connectivity Technology
- Wireless
- Interface
- 203 x 200 dpi
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm)
- Media Feeders
- 1 x manual - 1 sheet
- Networking
- Print server
- Data Link Protocol
- Bluetooth 2.0 EDR
- Connections
- 1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
- Included Accessories
- Cleaning kit
- Cables Included
- 1 x USB cable
- Software Included
- Brother P-touch Editor 5
- OS Required
- Limited warranty - 1 year
- 25.5 cm
- 5.5 cm
- 3 cm
- 473 g
