If you're pushed for space and time in your home office, Brother's compact HL-1110 is the ideal solution.
With up to 20ppm print speed, you won't be kept waiting – and as it delivers up to 600dpi resolution, you don't have to compromise print quality for speed. There's also a full-speed USB 2.0 interface so you can plug in and then print in minutes.
And if you've ever found yourself constantly refilling with paper, replacing toner or sorting paper jams, you'll surely appreciate the HL-1110's 150-sheet paper tray, 1,000 page cartridges and innovative anti-jam technology.
- Brother HL-1110 - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 4.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Interface
- USB 2.0
- Processor
- 200 MHz
- RAM Installed (Max)
- 1 MB
- Media Type
- Plain paper, recycled paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x
- Microsoft Certification
- Compatible with Windows 7
- 34 cm x 23.8 cm x 18.9 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 2400 x 600 dpi
- First Print Out Time B/W
- 10 sec
- Media Handling
- Processor
- 200 MHz
RAM
- 1 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), Folio (216 x 330 mm)
- Media Weight
- 65 g/m² - 105 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets weight: 65 g/m² - 105 g/m²
- Output Trays Capacity
- 50 sheets
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 10000 pages - Brother DR1050
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 380 Watt
- Power Consumption Stand by
- 40 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 51 dBA
- 34 cm
- 23.8 cm
- 18.9 cm
- 4.5 kg
Brother Drum Unit 10K | In Stock | £49.50 |
Brother Toner Cartridge | In Stock | £32.01 |
