MFC-L9570CDW
With an intuitive 17.6cm colour Touchscreen 2-sided scan speeds of 100ipm in colour and a choice of toner cartridges are only some of the highlights of this model.
Key Features
- Fast print speeds of up to 31ppm colour and mono
- 2-sided scan speeds of 100ipm colour and mono
- Paper input of up to 300 sheets
- Maximum paper input of up to
- 2380 sheets
- Automatic 2-Sided Printing
- Optional high-yield replacement cartridges 9000 black 9000 page cyan magenta and yellow toner cartridges
- High speed wired (10Base-T/100 Base-TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces
- Integrated NFC card reader
- Intuitive 17.6cm Colour Touchscreen
Increase productivity levels
- IProductivity is increased significantly thanks to the fast print speeds of up to 31ppm and 2-sided scan speeds of 100ipm in colour and mono.
- IMaximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
- IEasily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
- IOutstanding paper handling options with a standard paper capacity of up to 300 sheets expandable to 2380 sheets
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe with near field communication (NFC) functionality
Flexible and low running costs
Designed for high volume printing environments the MFC-L9570CDW includes a 6500 page black cyan magenta and yellow toners and can take an optional 9000 page black cyan magenta and yellow page toners to lower your running costs even further
Efficient connectivity
With a wide range of connectivity options including Gigabit Ethernet, NFC, USB 2.0, USB host, and Wi-Fi(n), the Brother MFC-L9570CDW ensures seamless integration into any work environment. Mobile printing capabilities through Apple AirPrint and Google Cloud Print 2.0 offer the flexibility to print from anywhere. -
High-quality printing and copying
Achieve high-quality prints and copies with max resolutions of 2400 x 600 DPI for both black and white and color. Automatic duplexing enhances productivity by facilitating double-sided printing and copying without manual intervention. -
Robust security features
The device is equipped with advanced security protocols including 802.1x, ARP, IPsec, Kerberos, SSL, TLS, WEP, WPA-PSK, and WPA2-PSK to protect sensitive information and ensure network security. -
Versatile media handling
Supports a wide range of media sizes and types, including glossy paper, labels, and recycled paper, making it suitable for diverse printing needs. The ADF and bypass feeder enhance flexibility in document handling. -
Comprehensive office solution
Combining the functions of a copier, fax, printer, and scanner with a recommended monthly volume of 6000 pages, this device is designed to meet the demands of busy office environments. Features like print from USB flash drive and scan to USB host add convenience and efficiency.
- Brother MFC-L9570CDW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 6000 pages
- Max Copying Speed
- Up to 31 ppm (mono) / up to 31 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 7"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 80 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 2380 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 49.5 cm x 52.6 cm x 54.9 cm
- 29.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 80000 pages
- 6000 pages
- Display Diagonal Size
- 7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, XPS
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 1200 x 600 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 350 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 80 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- 300 sheets
- 2380 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour , Scanning: up to 50 ppm - B/W , Scanning: up to 50 ppm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 100 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
- Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
- Voltage Required
- 580 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 10 Watt
- First Copy Out Time B/W
- 16 sec
- First Copy Out Time Colour
- 17 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 6500 pages , 1 x toner cartridge (cyan) - up to 6500 pages , 1 x toner cartridge (magenta) - up to 6500 pages , 1 x toner cartridge (yellow) - up to 6500 pages , 1 x drum - up to 50000 pages 3 pages per job - Brother DR421CL , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- 49.5 cm
- 52.6 cm
- 54.9 cm
- 29.7 kg
- Shipping Width
- 67.5 cm
- Shipping Depth
- 65.2 cm
- Shipping Height
- 72.6 cm
- Shipping Weight
- 36.1 kg
- Sound Emission
- 44 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother Waste Toner Pack | In Stock | £14.88 |
