Brother HL-L2400DWE Your Efficient A4 Mono Laser Printer
Quicklinx: HX0KWS00 Mfr#: HLL2400DWEZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
£430.43 ex VAT
£516.51 inc VAT
  • Efficient printing
    With automatic duplexing and a high-speed output of 30 ppm, this printer is designed to boost productivity in any work environment. Its ability to print on both sides of the paper reduces paper usage and provides a professional look to all documents.
  • High-quality output
    Achieve crisp, clear, and detailed prints with a maximum resolution of 1200 x 1200 DPI. Whether printing business documents or reports, the quality of the output is consistently impressive.
  • Versatile media handling
    Catering to a wide range of media sizes from A6 to A4 and types including bond paper, envelopes, labels, and recycled paper, this printer meets diverse printing needs. The inclusion of a 250-sheet input tray and a manual feed slot enhances its flexibility for various printing tasks.
  • Advanced connectivity
    Equipped with USB 2.0 and Wi-Fi interfaces, along with Brother Mobile Connect, this printer offers convenient wireless printing and easy integration into any network. Its comprehensive security features ensure safe and secure document handling.
  • Eco-friendly design
    Certified by ENERGY STAR and Blue Angel, this printer is recognized for its energy efficiency and reduced environmental impact. It operates quietly, with a sound emission as low as 30 dBA in idle mode, making it suitable for any office setting.
Brother HL-L2400DWE - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
Bundled Services
4 months EcoPro subscription
7.1 kg
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 15 spm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution Class (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Wi-Fi(n)
RAM Installed (Max)
64 MB
Media Type
Plain paper, thick paper, thin paper, recycled paper, bond paper, labels, envelopes, thicker paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Recommended Monthly Volume
Up to 2500 pages
Print server
Google Chrome OS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64 bits), Microsoft Windows Server 2016 (64-bit), Microsoft Windows Server 2019 (64-bit), Microsoft Windows Server 2022, Windows 10 Education (32/64 bits), Windows 10 Enterprise (32/64 bits), Windows 10 Home (32/64 bits), Windows 10 Pro (32/64 bits), Windows 11 Education, Windows 11 Enterprise, Windows 11 Home, Windows 11 Pro
35.6 cm x 36 cm x 18.3 cm
Printer Type
Workgroup printer - laser - monochrome
Bundled Services
Printer
Print Speed
Built-in Devices
1 line LCD display
Wireless
USB 2.0, Wi-Fi(n)
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Media Handling
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), ANSI A (Letter) (216 x 279 mm), JIS B5 (182 x 257 mm), B5 (190 x 250 mm), A5 (148 x 210 mm), JIS B6 (128 x 182 mm), A6 (105 x 148 mm), Executive (184 x 267 mm), 195 x 270 mm, 76.2 x 127 mm, 215.9 x 355.6 mm
Envelope Sizes
Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 230 g/m²
250 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray: 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 230 g/m² , Output tray: 1 - 150 sheets
Output Trays Capacity
150 sheets
Duty Cycle
Up to 2500 pages
Print server
Remote Management Protocol
HTTP, IPP, SMTP
Security Protocols & Features
Wi-Fi Direct, WEP, WPA2-PSK, WPA3-SAE, WPA-PSK, TKIP, AES, SMTP, SSL, TLS, SNMP 3, 802.1x, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, POP3, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure key management
1 x USB 2.0
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 15000 pages 1 page per job - Brother DR2510
Power supply - internal
440 Watt
Power Consumption Stand by
43 Watt
Power Consumption Sleep
3.8 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
48 dBA
Sound Emission (Quiet Mode)
44 dBA
35.6 cm
36 cm
18.3 cm
7.1 kg
Width (Shipping)
43.8 cm
Depth (Shipping)
28.3 cm
Height (Shipping)
51.9 cm
Weight (Shipping)
8.2 kg
Type: Printer
Wireless Capability: Wireless
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
