The improved DCP-L8410 packs a powerful punch, offering professional quality color printing for today's demanding business environment. Not only that, but it has low total cost of ownership (TCO) and improved connectivity - including scan and print compatibility with mobile devices and cloud-based services. That makes it ideal for connecting with mobiles and tablets, embracing the 'bring your own device' revolution in the workplace.
Key features
- High speed 31ppm colour & mono
- 28ipm scan speed colour & mono
- 9.3cm touchscreen
- 300 sheet paper capacity
- USB Wireless and Gigabit Wired network
- 3000 Black and 1800 Cyan Magenta & Yellow Toners Inbox
Efficient connectivity
With a variety of interfaces including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print 2.0, this device ensures seamless connection and printing from virtually anywhere. -
High-quality printing
Achieve professional, high-resolution prints with up to 2400 x 600 DPI for both black and white and color documents, complemented by automatic duplexing for efficient two-sided printing. -
Versatile media handling
Supports a wide range of media sizes from A4 to Legal, and types including envelopes, labels, plain paper, and more, making it suitable for various printing needs. -
Advanced scanning capabilities
Offers detailed scanning with an optical resolution of 1200 x 2400 DPI, color depth of 24-bit, and interpolated resolution up to 19200 x 19200 DPI, ensuring clear and vibrant digital copies. -
Eco-friendly design
ENERGY STAR certified and Blue Angel compliant, this printer operates efficiently, with a low power consumption in sleep mode of just 10 W, reducing environmental impact and operational costs.
- Brother DCP-L8410CDW - multifunction printer - colour
- Multifunction printer
- Localisation
- United Kingdom
- Printing Technology
- Laser (colour)
- Recommended Monthly Volume
- 3000 pages
- Max Copying Speed
- Up to 31 ppm (mono) / up to 31 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 43.5 cm x 52.6 cm x 53.9 cm
- 27.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty
- Laser - colour
- 3000 pages
- Display Diagonal Size
- 3.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 600 dpi - ADF , 1200 x 2400 dpi - flatbed
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Scanning: up to 28 ppm - B/W , Scanning: up to 28 ppm - colour , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
- Voltage Required
- 580 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 10 Watt
- First Copy Out Time B/W
- 16 sec
- First Copy Out Time Colour
- 17 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x drum - up to 50000 pages 3 pages per job , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 43.5 cm
- 52.6 cm
- 53.9 cm
- 27.6 kg
- Shipping Width
- 66.3 cm
- Shipping Depth
- 54.2 cm
- Shipping Height
- 65.4 cm
- Shipping Weight
- 33.3 kg
- Sound Emission
- 44 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother Waste Toner Pack | In Stock | £14.94 |
