HL-L8360CDW
Wireless colour laser printer with intuitive security functions.
Key Features
- Fast print speeds of up to 31ppm colour and mono
- Paper input of up to 300 sheets
- Maximum paper input of up to 2380 sheets
- Automatic 2-Sided Printing
- Optional Super high-yield replacement cartridges 9000 black 6500 cyan magenta and yellow toner cartridge
- Built-in Ethernet 10Base-T/100Base-TX /1000Base-T
- Integrated NFC Reader
- Intuitive 6.8cm colour touchscreen
Increase productivity levels
- Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
- Maximise your efficiency with built-in wireless IEEE 802.11b/g/n andethernet 10Base-T/100Base-TX/1000Base-T.
- Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
- Outstanding paper handling options with a standard paper capacity of 300 sheets expandable to 2380.
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe and secure near field communication (NFC) functionality.
Flexible and low running costs
Designed for flexible printing requirements the HL-L8360CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take an optional high yield 6500 page black and 4000 page cyan magenta and yellow page toners to lower your running costs even further. Together with a further cost saving of taking super high-yield replacement cartridges of 9000 black 6500 cyan magenta and yellow toner cartridge.
Fast, high-quality business printing
With print speeds up to 33 pages per minute in both color and black and up to 2400 x 600 dpi class resolution, you no longer have to wait for high-impact business documents. -
Low cost printing
Spend less time replacing supplies and help reduce operating costs by using Brother genuine super high-yield 6500-page replacement toner cartridges. -
Flexible network connectivity
Built-in wireless 802.11b/g/n and Gigabit Ethernet network interfaces to easily setup and share on your wireless or wired network. -
Convenient mobile device printing
Print from your mobile device via AirPrint, Mopria, Brother iPrint&Scan, Wi-Fi Direct, and NFC. -
Easily print two-sided documents
Use the automatic duplex print feature to help reduce your printing costs and produce professional two-sided documents, presentations, brochures, and booklets.
- Brother HL-L8360CDW - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21.9 kg
- Localisation
- United Kingdom
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB
- Language Simulation
- PostScript 3, PCL 6, XPS, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Recommended Monthly Volume
- 4000 pages
- Networking
- Print server
- 2-year warranty
- 44.1 cm x 48.6 cm x 31.3 cm
- Printer Type
- Localisation
- United Kingdom
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
- Fonts Included
- 66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Sheets in Multi-Part Form
- 2380
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x waste toner collector - up to 50000 pages - Brother WT320CL , 1 x drum - up to 50000 pages 3 pages per job , 1 x transmission belt - up to 130000 pages 3 pages per job
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 580 Watt
- Power Consumption Stand by
- 70 Watt
- Power Consumption Sleep
- 10 Watt
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49 dBA
- Sound Emission (Quiet Mode)
- 44 dBA
- 44.1 cm
- 48.6 cm
- 31.3 cm
- 21.9 kg
- Width (Shipping)
- 61.7 cm
- Depth (Shipping)
- 55.8 cm
- Height (Shipping)
- 52.1 cm
- Weight (Shipping)
- 25.9 kg
Brother Waste Toner Pack | In Stock | £14.82 |
