Brother MFC-L9550CDWT Colour Laser Multifunction Printer
Quicklinx: 9JD9WS00 Mfr#: MFCL9550CDWTU2
Wherever the all-new MFC-L9550CDWT goes head-to-head against competitors in the small corporate market, you'll find it comes out on top.
Ideal for workgroups of up to 20 with a heavy print load, it offers professional quality colour combined with the reliability and performance of the undisputed number 1 brand in mono and AIO lasers.*
It also combines exceptional efficiency with our lowest ever total cost of ownership and embraces the 'Bring Your Own Device' revolution with quick & easy wireless connection to mobile devices. Meaning staff and visitors alike can print to and scan from the MFC-L9550CDWT using a wide range of smartphones and tablets.
*Jan-Dec 2013.
  • Efficient connectivity
    With a variety of interfaces including LAN, USB 2.0, USB host, and Wi-Fi(n), alongside AirPrint Enabled for seamless mobile printing, this device ensures you stay connected in any work environment.
  • High-quality copying
    Achieve crisp, clear copies with automatic duplexing and a maximum copying resolution of 1200 x 600 DPI for both black and white and color documents, enhancing your productivity.
  • Versatile media handling
    Supports a wide range of media sizes from A4 to Legal, and types including plain, bond, and recycled paper, making it ideal for diverse printing needs. The device's maximum media capacity of 800 sheets allows for extended printing without frequent reloads.
  • Advanced scanning capabilities
    Features automatic duplexing in scanning with an optical resolution of 1200 x 2400 DPI and an interpolated resolution up to 19200 x 19200 DPI, ensuring detailed and high-quality scans.
  • Eco-friendly operation
    Designed with an idle sound emission of just 28 dBA and operational sound emission of 56 dBA, this device operates quietly, minimizing noise in your workspace.
Brother MFC-L9550CDWT - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1000 - 5000 pages
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, bond paper
Standard Media Capacity
800 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
49 cm x 53.5 cm x 66.2 cm
37.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
75000 pages
1000 - 5000 pages
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
PC Faxing
Fax Machine Features
Duplex Fax
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
800 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , Input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, 802.1x, EAP-TTLS, EAP-TLS, EAP-FAST
Operating System Support
Linux, MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
AC 230 V (50/60Hz)
565 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
10.5 Watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 6000 pages - Brother TN900BK , 1 x toner cartridge (cyan) - up to 6000 pages - Brother TN900C , 1 x toner cartridge (magenta) - up to 6000 pages - Brother TN900M , 1 x toner cartridge (yellow) - up to 6000 pages - Brother TN900Y , 1 x drum - up to 25000 pages - Brother DR321CL , 1 x belt - up to 50000 pages - Brother BU320CL , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
Nordic Swan, IEC 60825-1:2007
ENERGY STAR Certified
Blue Angel Compliant
49 cm
53.5 cm
66.2 cm
37.4 kg
Shipping Width
66 cm
Shipping Depth
62.5 cm
Shipping Height
99.2 cm
Shipping Weight
45.6 kg
Sound Emission
28 dBA (idle) / 56 dBA (operating)
