Brother MFC-L8650CDW Colour Laser Multifunction Printer
Quicklinx: 9JD5WS00 Mfr#: MFCL8650CDWZU1
Speed is everything in a competitive marketplace and the MFC-L8650CDW delivers print that's not only faster, but also more productive, smarter and more economical. Best-in-class print speeds of up to 28ppm - colour or mono - keep productivity up, while high yield toners and automatic 2-sided printing keep running costs down.
With a 9.3cm touchscreen LCD screen, all users can quickly select this multifunction printer's many easy-to-use features and settings. And if they're tied up elsewhere, they can still take advantage of its comprehensive mobile connectivity to scan, print and share from their smartphones and tablets using Brother's specialist apps.
Brother MFC-L8650CDW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
500 - 3000 pages
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 28 ppm (mono) / up to 28 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
AC 230 V (50/60Hz)
41 cm x 50.3 cm x 49.2 cm
30.4 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 pages
500 - 3000 pages
Display Diagonal Size
3.7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Broadcast Transmission
350 stations
Group dialling
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W , Printing: up to 28 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, Apple Mac OS X 10.7.5, MS Windows Server 2012 R2 x64 Edition
AC 230 V (50/60Hz)
565 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
9.5 Watt
First Copy Out Time B/W
18 sec
First Copy Out Time Colour
20 sec
Consumables Included
1 x toner cartridge (black) - up to 2500 pages - Brother TN321BK , 1 x toner cartridge (cyan) - up to 1500 pages - Brother TN321C , 1 x toner cartridge (magenta) - up to 1500 pages - Brother TN321M , 1 x toner cartridge (yellow) - up to 1500 pages - Brother TN321Y
41 cm
50.3 cm
49.2 cm
30.4 kg
Sound Emission
28 dBA (idle) / 55 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
