- New build design delivers a more robust and easy to operate device suited to a busy work environment
- A new and improved print head increases machine life and ensures exceptional durability
- Stay prepared with a 500-sheet capacity paper tray and a 100 sheet multi-purpose tray for printing on a wide range of media
- Enjoy fast and hassle free scanning of multi-paged documents with the 50 sheet Automatic Document Feeder
- Reduce print costs and paper usage with automatic 2-sided print
- Show off your sharp black text and vivid colour prints with new pigment based inks
- Save time and money with optional high yield cartridges that deliver yields up to 3,000 mono and 1,500 colour pages
- Stay connected with smartphone, tablet, laptop and desktop compatibility
- With wireless and Wi-Fi Direct you don't need a router to connect
- Scan to popular cloud storage facilities directly from the large 9.3cm intuitive swipe touchscreen
- Capture and convert documents with ease with our exclusive Brother Cloud Apps
- Brother Business Smart Pro MFC-J6930DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, recycled paper, photo paper, coated paper, glossy paper
- Standard Media Capacity
- 600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive
- Power
- AC 230 V (50/60Hz)
- 57.5 cm x 37.45 cm x 47.7 cm
- 23.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 2000 pages
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Ireland
- Standard Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- One-Touch Dialing
- 6 station(s)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 250 stations
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 600 sheets
- 100 sheets
- 100 sheets
- 2 x input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 90 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 22 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Copying: up to 12 ppm - B/W , Copying: up to 9 ppm - colour , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Printing: up to 12 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm - colour duplex (ISO/IEC 24734) , Printing: up to 35 ppm - B/W fast , Printing: up to 27 ppm - colour fast , Scanning: up to 8 ipm (A3) - B/W , Scanning: up to 8 ipm (A3) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, WPS, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
- Voltage Required
- 29 Watt
- Power Consumption Standby
- 6.5 Watt
- Power Consumption Sleep
- 1.7 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 57.5 cm
- 37.45 cm
- 47.7 cm
- 23.6 kg
- Shipping Width
- 68.1 cm
- Shipping Depth
- 50 cm
- Shipping Height
- 56.8 cm
- Shipping Weight
- 28.3 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
Ink (8)
Brother Magenta Super High Yield Ink Cartridge | In Stock | £22.27 |
Brother Yellow Super High Yield Ink Cartridge | In Stock | £22.31 |
Brother Black Super High Yield Ink Cartridge | In Stock | £33.90 |
Brother Cyan Super High Yield Ink Cartridge | In Stock | £22.54 |
Brother Cyan Ink Cartridge | In Stock | £12.57 |
Brother LC3217BK Original Black Ink Cartridge | In Stock | £17.37 |
Brother Magenta Ink Cartridge | In Stock | £12.73 |
Brother LC3219XLVAL Value Pack | In Stock | £76.01 |
Other bundles (1)
Brother A3 GLOSSY PAPER | In Stock | £16.41 |
